Yeah, cutting the wire is the best option as your warning light still comes on when your power steering fluid is low. Just unplug the computer and then with the car on, go through all the wires connecting them with another piece of wire and see which one turns the light on. Then cut that wire, plug it all back in and drive :D
https://www.sau.com.au/forums/topic/171599-hiacs-light/#findComment-3163326
is it that hard to manually look at the power steering level? You have to check the coolent and oil manually.
It's not hard, but I'd say cutting one wire is easier than taking the dash out, and yes, I've done both. It's not really a necessity, it's just nice to have it there in case something goes wrong, you can notice it earlier I guess.
As for cutting the wrong wire, I wouldn't stress too much, just check them all by connecting them seperately until you find the one that lights up the dash light. Then cut that wire, and plug the plugs back in. Pretty simple, it took me 5mins to find the wire to cut on my R32. If they're like R32 at all, it'll be the green with white trace line wire on the smaller of the two plugs. Dont just cut that wire without checking though, chances are, R32 is different to R33.
https://www.sau.com.au/forums/topic/171599-hiacs-light/#findComment-3163927
So when the fluid in your p/s resevoir gets low the HICAS light doesn't come on? I thought it would be similar to how the handbrake light comes on when your brake fluid is low...
It is for R32s anyway, could be different for R33s. Seems odd that they would change it though?
https://www.sau.com.au/forums/topic/171599-hiacs-light/#findComment-3166869
Salad, being electronic driven in the 33's, there is no Power steer fluid going to the rear, thus no link between hicas and power steer fluid levels.
So has anyone identified which wire it is for the R33's? I pulled the fuse on hicas to make sure it won't operate (until I can get a lock bar) and the light is giving me the shits!
https://www.sau.com.au/forums/topic/171599-hiacs-light/#findComment-3167101
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
