Hi
My R32 when started cold stalls straight away if you dont rev it as soon as you start it.
What can cause this issue? thought it was a dodgy cheap ass battery but I swapped it with a good working one and same issue.
Please advice
Thanks
https://www.sau.com.au/forums/topic/171710-starting-issue-stalls/
mine has been doing that lately, but thats cause it has been sitting in the cold, not being driven...
i think its just everything is cold... theres a slight chance it could be a lack of power, but i doubt it...
does it only do it when its cold? cause my 33 stalled last night, and its being worked on, so it hasn't been run for a little while... it wouldn't idle properly... not at first...
other then that, its never had a problem before...
The car starts but for like 3 secs cos its idling very very low then stalls
if I start it and blip or rev the throttle a little bit it idles like normal (cold start higher rev) and runs fine, starts straight away when warm
I've read that if its the air regulator it'll idle high as well when warm, so this cant be my issue then...
AAC valve is when you have crap idle but my car idles fine.
Can someone please share some ideas
Could be the AAC not going to 100% on startup for cold start idle and staying at the 30% ????
Or is it the other way round???? Damn financial year end messing my brain up :closedeyes: Meh either way.... definitely check the AAC valve... I had this problem... car idled fine just took a couple of goes to keep it running in the morning!
*edit* we also found that the ignition switch was worn - if it takes a while to crank over too, check the voltage on it. I originally thought my issue was fuel on cold start (aftermarket ecu) ended up being 2 problems - ignition switch dropping current resulting in excessive cranking before firing and then the AAC being dodgy and not opening all the way for cold start and causing the stalling issue after a second or two.
Under the throttle body (guessing RB20DET), is a "cold start air valve". Can't recall if it's supposed to be open or closed at (cold) start, but then a bi-metallic strip cause it to close or open.
Pull it off, peer down the barrel. Tell us what you observe.
Yeah mine has starting problems also on cold mornings;
Here is a video;
Similar to your starts?
Just blip the throttle when car starts, thats what i do
edit;
this might help also
http://www.skylinesaustralia.com/forums/in...=162728&hl=
cranks fine
Rekin very similar but mine goes to normal cold start idle like 1500rpm, your's a bit low...
Yes just blip the throttle and everythings fine.
But I still want to sort it out as it shouldnt be like that.
what does the cold start air valve looks like? is it like the air regulator?
It's the only thing under the throttle body. Hoses attached to both ends. You can't miss it (unless you're blind!).
Actually, starting to sound a bit like dirty injectors. Had them cleaned recently?
Hey guys, i have the same problem and even better i know how to fix it!
my engine temp sensor is kaput, it is giving a higher resistents level then it should have been which indicates to the ECU that the engine is hotter then its actually is. the result is the wrong mixture of actions and fuels during startup which results in the stall.
i havn't had a chance to get myself a new sensor since uni is kicking my ass but i'm confident this will fix the issue.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
