Hey guys, not sure where to put this sorta topic. But here it goes..
I've noticed recently a "grinding" noise from my engine bay, when accelerating from around 1500, and fading away at 2000 rpm.
It's not a BAD grinding noise.. its not like going from 5th gear down to reverse :D , but a gradual rattling/scraping sound getting softer then dissapearing as the RPM's pick up.
Would anyone have an idea of what it could be? And what I could do to remedy this? Or is it something that I can live with?
Cheers guys!
https://www.sau.com.au/forums/topic/171723-name-that-sound/
It's not a BAD grinding noise.. its not like going from 5th gear down to reverse :rofl: , but a gradual rattling/scraping sound getting softer then dissapearing as the RPM's pick up.
Cheers guys!
TIMING BELT!
I had the same sound a month ago,....gaaaaaaawn, after TB changed!!
PS....this new SAU server sux!
https://www.sau.com.au/forums/topic/171723-name-that-sound/#findComment-3165312
Got a similar thing, car makes this weird 'rough' sound which sounds a little bit rougher then normal idle but it disappears when you depress the clutch. Looks like more excuses not to buy an exhaust! :P
Hi,
that 'particular' noise could be (and most probably is) your thruster bearing, located in your gearbox.
It's a $5.00 part that requires approx $500 in labour....that sux!!
Bye....
https://www.sau.com.au/forums/topic/171723-name-that-sound/#findComment-3169169
Hi,
Bye....
haha cheers for sharing, im off to go cry
https://www.sau.com.au/forums/topic/171723-name-that-sound/#findComment-3169261
Ă—
Ă—
