Oh bugger, I'm away this weekend - RAINCHECK - Whens the next one?
Probably when the next public holiday rolls around,LOL!! Seriously, we used to get together regularly, but distance, weather, finaces etc slowed that idea a bit, so I thought this would be a good idea to catch up with the crew...
Someone help Shell out with a lift! The lady works hard,as we all do,and deserves a drink or three! Moreso, I've never met the mythical person who is Shell, and this seems like the only time we'd both be at the same place within the next millenia...
lol yeah good night, great to catch up with the old crew again, now after many of conversations telling me to keep the car, I may just do that. See what happens.
Thanks again for Donnan for dropping me home. The couple of beers was at least I could do.
Sorry guys for the mid run out for a domesticish issue, who was there knows!!!
Agreed was a good night, great to meet nsanity and donnan as well as seeing all the a lot of faces I have not seen in a while Snooze, Shell, Jayce and E
Damn I missed all the excitement :) did you not tell Amaru you were going out again. You know he doesn't like that :)
Thanks all for making the effort to come along last night; great to catch up with friends! I'm stoked I finally got to meet the fabled & mysterious Shell,LOL!!
Seriously, great to catch up with y'all! I hope no one got booked or had any run-ins on the way home. Both the local constabulary and the 'Roos have been a bit jumpy as of late...
Soz JnE woulda been good, by the sounds a good turn out, and you know how I like my burbons. :)
:) ta Snooze, nxt one.
How's the Qld'ers going to go in Sydney? We might get trounced Jayce. Lucky it's best of 3!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
