Okay, here is my footage from the day. I have cut them up into individual movies, and encoded them as low quality to make it easier on you modem users :P
Sorry I don't know who's everyones cars are, so the names are pretty generic :D
Note: Please dont hammer the site, as all files are hosted on my own website... However, feel free to pass the downloaded files around :)
>>> Skylines
4 Door R33
Download Video 314kb
Grey R32
Download Video 432kb
Grey R33
Download Video 361kb
R31 GTS
Download Video 462kb
Silver R33
>>> 180SX
Both the 180's
Download Video 1 1300kb
Download Video 2 793kb
Download Video 3 761kb
Download Video 4 312kb
Download Video 5 930kb
Download Video 6 347kb
>>> Commodores
Black VY SS
Download Video 246kb
Blue Supercharged Monaro
Download Video 1 871kb
Download Video 2 1400kb
Download Video 3 989kb
Download Video 4 560kb
BRUTE Ute
Download Video 1 336kb
Download Video 2 264kb
Download Video 3 493kb
Silver Senator
Download Video 1 260kb
Download Video 2 243kb
Silver VX SS
Download Video 401kb
Black VX GTS
Download Video 407kb
VL Walkinshaw Turbo 6
Download Video 333kb
>>> Miscellaneous Others
Black Soarer
Download Video 1 673kb
Download Video 2 254kb
Download Video 3 587kb
Download Video 4 328kb
Excel Turbo
Download Video 497kb
Holden Kingswood
Download Video 1200kb
Lancer EVO
Download Video 366kb
Mad Dat
Download Video 661kb
9 second Rotory
Download Video 1300kb
Red 300ZX
Download Video 442kb
https://www.sau.com.au/forums/topic/17177-video-may-31st-drag-meet-footage/
My car? It's actually a silhouette with grille from the GTS model coupe. Limiter? GTS model's of the Aust skylines were white with white rims (made 130kw) or red with white rims (made 140kw). Both cars were four door too.
I drive the way a car should be driven... hehe Nar it loves flat changes.. R32 box bolts straight in so im not too fussed if it dies on me. I know it sounds sad but i really wanted to get below 15.5 lol
What I meant by the limiter is I heard just before gear changes a couple of pops on the GTS Commodore. Hence bouncing off the rev limiter slightly then changing gears.
I would be happy with a mid 15 run from a basically stock R31.. :D
Quicker than an EL XR6.. :P
I have got a heap of vid runs from my digi cam ... will burn a few CDs off and keep them in my car - if anyone wants one give me a ring and we can catch up - otherwise c u at the cruise
I have an older video 8 style non digital, non firewire camera. Is there any kit getting around that allows you to be able to copy to some type of mpg/vcd style formatt. Or would the expense be better served rolled into a new camera. I probably will post this in a more general thread as well. I also have good footage from various events around Adelaide.
Thanks
Mine was taken from a non digital camera. You just need a video capture card in your PC. Whether its a standalone one which you can get for around $70 or some of the higher end video cards have capture built in. You could then just use Microsoft Movie Maker (comes with windows) to make your movies without stuffing around much at all.
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
