  • Replies 111
are you in a mood to sell off the intake pipes from the pods? and the centre dash trim?
if you are, ill take them.
Edited by SLIPPERY
NEED THE LOT GONE THIS WEEKEND AT CHEAP CHEAP PRICES BRING YOUR TOOLS CAUSE YOU WILL NEED TO RIP IT OUT YOUR SELF WITH MY HELP IF NEEDED PM ME WITH WHAT YOU WANT
alloy radiator
motor
box
diff
seats
coola
hks piping kit
hks suspention
after market front top control arms
hks bov
twin 3"off each dump to single 4" to single hi flow muffla to hks super drager tip
so much to mention
Edited by ANK
can you pm me a price for the HKS piping kit? ive been after one for a few months now :mrt:
tell me what they normaly go for and i will deside please pm me as well u able to pick it up also?
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
