Fuel Problems
i have a quick question i need some help sortin out, i have a 95 gtst with front mount, exhaust and its runnin 10 pound, im only gettin 200 kms out of a full tank of 98 octane is this normal? any help would be appreciated.
i used to get about 250kms to about 45L.
how many litres are you classing as a tank? put it into litres per 100kms. i was getting around 17, but i am a bit of a lead foot.
dude wtf u guys have turbo cars and get that much Ks..
ive got a na r34 and the max i can get out of a full 70dollar tank is 300Ks MAX.
and i dont even have a heavy foot
all ive got is a 3inch pipe form the engine to back wif a 4inch tip..
a tank is 45 litres so im guessing that i get about 22.5 litres per 100ks, which is ridiculous, i dont have a heavy foot but i do drive a lot of short distances do u think that this is the problem
if you do alot of stop and start driving and short trips you'll burn a hell of a lot more fuel than highway driving i used to get that sorta range when i was doing runaround driving in the city, also double check the last time your got a tune up.
A way you can gain more kms is to change to new oxygen sensors, new fuel filter, change back to stock air box and I think cleaning your air flow meter helps, but if your always having short trips, that explains why you don't get much out of a tank.
the fact that you do short trips doesn't help.
try getting a new o2 sensor. it may also be that your water temp sensor is dodgy as well so it is constantly running on cold start enrichment even when it is warm, or your thermostat may be a bit dodgy and making the car run cooler, which has a similar effect.
also where you live can make a difference too. where i live is hilly, so that means you will use more fuel than somewhere that is flat.
yer, as these guys say, im convinced its more the distance of driving you do than how you drive
as soon as i get out on the highway, i get much much better economy, than the normal driving to and from work
would easily get 400/450 ks to a tank on the highway, close to 300/350 to from work
whaaa???????
My tank is 61litres.....
and I average 10-11 litres per 100km (3" turbo back and a pod) and I dont drive slow either...
There is deffinately something wrong with your cars fuel consumption!!!
02 sensor problem maybe? that will hinder on fuel consumption, i get 300 k's with 16psi modded engine and turbo and thats non conservative driving, id get it looked at or check the 02 sensor that may be a start or tune with aftermarket computer
Unless my understanding of the narrow-band O2 sensor is wrong, it is for closed loop feedback. ie. cruise conditions. Unlikely that will have any impact on crappy fuel consumption if you are only doing 2-3km short run driving.
Cold start / low temp enrichment comes from the engine temp sensor feedback into the ECU. Yeah, you could alter the signal if you're savvy with electronics but it would likely run like a dog until warm.
I suggest you plan a weekend away, and just do some cruising. Steady speeds, off boost, and actually LOG your fuel usage from full tank back to full tank. Then see what results you have over 5-600km.
Many people don't know how to drive to achieve great economy, and FWIW, you don't have a vehicle designed to achieve it either.
I'm also running about 10psi. I get to 300k when the needle is almost to the empty but have not had the fuel light come on yet so could probably get more. I am also a lead foot. I used to get only about 220k when I was runnin 16psi on an aftermarket computer.
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
