Fuel Problems
i have a quick question i need some help sortin out, i have a 95 gtst with front mount, exhaust and its runnin 10 pound, im only gettin 200 kms out of a full tank of 98 octane is this normal? any help would be appreciated.
i used to get about 250kms to about 45L.
how many litres are you classing as a tank? put it into litres per 100kms. i was getting around 17, but i am a bit of a lead foot.
dude wtf u guys have turbo cars and get that much Ks..
ive got a na r34 and the max i can get out of a full 70dollar tank is 300Ks MAX.
and i dont even have a heavy foot
all ive got is a 3inch pipe form the engine to back wif a 4inch tip..
a tank is 45 litres so im guessing that i get about 22.5 litres per 100ks, which is ridiculous, i dont have a heavy foot but i do drive a lot of short distances do u think that this is the problem
if you do alot of stop and start driving and short trips you'll burn a hell of a lot more fuel than highway driving i used to get that sorta range when i was doing runaround driving in the city, also double check the last time your got a tune up.
A way you can gain more kms is to change to new oxygen sensors, new fuel filter, change back to stock air box and I think cleaning your air flow meter helps, but if your always having short trips, that explains why you don't get much out of a tank.
the fact that you do short trips doesn't help.
try getting a new o2 sensor. it may also be that your water temp sensor is dodgy as well so it is constantly running on cold start enrichment even when it is warm, or your thermostat may be a bit dodgy and making the car run cooler, which has a similar effect.
also where you live can make a difference too. where i live is hilly, so that means you will use more fuel than somewhere that is flat.
yer, as these guys say, im convinced its more the distance of driving you do than how you drive
as soon as i get out on the highway, i get much much better economy, than the normal driving to and from work
would easily get 400/450 ks to a tank on the highway, close to 300/350 to from work
whaaa???????
My tank is 61litres.....
and I average 10-11 litres per 100km (3" turbo back and a pod) and I dont drive slow either...
There is deffinately something wrong with your cars fuel consumption!!!
02 sensor problem maybe? that will hinder on fuel consumption, i get 300 k's with 16psi modded engine and turbo and thats non conservative driving, id get it looked at or check the 02 sensor that may be a start or tune with aftermarket computer
Unless my understanding of the narrow-band O2 sensor is wrong, it is for closed loop feedback. ie. cruise conditions. Unlikely that will have any impact on crappy fuel consumption if you are only doing 2-3km short run driving.
Cold start / low temp enrichment comes from the engine temp sensor feedback into the ECU. Yeah, you could alter the signal if you're savvy with electronics but it would likely run like a dog until warm.
I suggest you plan a weekend away, and just do some cruising. Steady speeds, off boost, and actually LOG your fuel usage from full tank back to full tank. Then see what results you have over 5-600km.
Many people don't know how to drive to achieve great economy, and FWIW, you don't have a vehicle designed to achieve it either.
I'm also running about 10psi. I get to 300k when the needle is almost to the empty but have not had the fuel light come on yet so could probably get more. I am also a lead foot. I used to get only about 220k when I was runnin 16psi on an aftermarket computer.
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
