I just installed an atmo bov HKS SSQ, and blocked the return pipe with a nice blue bottle cap.
And now Im having the common stalling issue on my R32
car is stock aside from the obvious bov
I know I can just switch back to stock bov or plumb a return line on the aftermarket HKS
I've read some people dont even get this problem (lucky bastards!!!)
How do I adjust the idle to go higher a little bit?
dont really wanna buy an aftermarket computer right now too much $$$ from buying the car.
I'd give it a few weeks and I'll go back to stock, I just want to enjoy my 1st turbo car but dont wanna stall everytime i press the clutch or stop at lights.
My HKS bov is one of the 1st series that doesnt have the adjustment bolt to tighten the valve/spring.
here's the pics after install
Cheers
https://www.sau.com.au/forums/topic/171836-hks-ssq-bov-stalling-issue/
For starters, note that BOV's are illegal - a bastard copper will give you a defect notice on the spot plus a nifty fine if he catches you UNLESS..... you get the drift. Does hide and seek mean anything to you?
And no, sorry, I don't have a HKS SSQ so can't help - I got a Greddy one.. makes the meaniest sound... it's like..... VVVVVVVVVOOOOOO TU TU TUT TUTU UTU... LOL
yeah spunky munky is out on a post count mission im pretty sure,
you will find pretty much any atmo venting bov will give u stall issues on a stock line, best thing to do is put up with the stalling for the three months it will take u to get over the friggen noise then go back to stock haha.
goodluck man :action-smiley-069:
had the same issue with my car, everytime i clutched in or stopped the car. it would stall. but this only hjappened after hard accell. normal driving its fine. i have a PFC and thats the only way i know of putting the revs higher. my revs sit at 1000rpm
as aposed to the normal 800
I had the same problem mate. Mine did get better over time though as it seemed to happen less and less. I had the old style HKS Sequential BOV and I just tightened the screw up more and it seemed to go away. Maybe give that a go?
my SSQ doesnt have the adjustment screw/bolt
Today adjusted the idle speed and it didnt stall all the time only once when it wasnt even boosted...funny
I set the idle to 800-900 rpm and seems to be OK but still stalls
I've read that I can use HKS Electronic Idle Stabiliser to overcome this issue.
Might give that a try...
or the more expensive Apexi SAFC
Edited by Rob_C110GTR
or just save urself a few bucks and go back the stock bov. the issue is ur venting out the air your afm has already measured and this is making ur car run like crap doesnt matter what u do without some sort of air flow/fuel correction your cars gonna stall and be crap to drive. is it really worth the sound??
as I explained from the 1st post I'd like to have it for a weeks then back to stock BOV
just to experience it, Im pretty sure you did as well with your 1st turbo car...
so enough with going back to stock BOV
i know that already
just wanna try and make the stalling a bit bearable.
Cheers
oh ok then nah worries. yeah i had a blow off valve experienced your probs and took the thing off after 1 hour of having it on. But hey people buy turbo cars for different reasons. Best bet for you would be to buy a cheap safc from ebay it wont make the problem bareable it will fix your prob completely :) good luck.
Having a PFC will FIX the problem,
If you have a PFC and your car still stalling then your TUNER don't know how to TUNE the PFC properly. Apart from that, atmo bov will stall your RB25 as everytime you change gear, the stock ECU will dump a bit of fuel in and now there is no return air, all the suddem your car runs so RICH.
the reason no one ever bothered to solve the problem was that in the end we all realised how pointless it was to try to fix it. You can spend hundreds of dollars trying to solve this problem, buy this and buy that when you can simply solve it for free by putting the stock one back on. For most people, the novelty of the sound wears off after about a couple of weeks and the problem sovlves itself.
I don't know if this will help,but, i read a post a while back about this guy using his stock BOV, and having a vent to atmo. BOV just after the Intercooler pipe. ? you'd have to get a exhaust shop to install it for you and you should be alright. please correct me if I'm wrong.
good luck mate.
Aif
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
