I just installed an atmo bov HKS SSQ, and blocked the return pipe with a nice blue bottle cap.
And now Im having the common stalling issue on my R32
car is stock aside from the obvious bov
I know I can just switch back to stock bov or plumb a return line on the aftermarket HKS
I've read some people dont even get this problem (lucky bastards!!!)
How do I adjust the idle to go higher a little bit?
dont really wanna buy an aftermarket computer right now too much $$$ from buying the car.
I'd give it a few weeks and I'll go back to stock, I just want to enjoy my 1st turbo car but dont wanna stall everytime i press the clutch or stop at lights.
My HKS bov is one of the 1st series that doesnt have the adjustment bolt to tighten the valve/spring.
here's the pics after install
Cheers
https://www.sau.com.au/forums/topic/171836-hks-ssq-bov-stalling-issue/
For starters, note that BOV's are illegal - a bastard copper will give you a defect notice on the spot plus a nifty fine if he catches you UNLESS..... you get the drift. Does hide and seek mean anything to you?
And no, sorry, I don't have a HKS SSQ so can't help - I got a Greddy one.. makes the meaniest sound... it's like..... VVVVVVVVVOOOOOO TU TU TUT TUTU UTU... LOL
yeah spunky munky is out on a post count mission im pretty sure,
you will find pretty much any atmo venting bov will give u stall issues on a stock line, best thing to do is put up with the stalling for the three months it will take u to get over the friggen noise then go back to stock haha.
goodluck man :action-smiley-069:
had the same issue with my car, everytime i clutched in or stopped the car. it would stall. but this only hjappened after hard accell. normal driving its fine. i have a PFC and thats the only way i know of putting the revs higher. my revs sit at 1000rpm
as aposed to the normal 800
I had the same problem mate. Mine did get better over time though as it seemed to happen less and less. I had the old style HKS Sequential BOV and I just tightened the screw up more and it seemed to go away. Maybe give that a go?
my SSQ doesnt have the adjustment screw/bolt
Today adjusted the idle speed and it didnt stall all the time only once when it wasnt even boosted...funny
I set the idle to 800-900 rpm and seems to be OK but still stalls
I've read that I can use HKS Electronic Idle Stabiliser to overcome this issue.
Might give that a try...
or the more expensive Apexi SAFC
Edited by Rob_C110GTR
or just save urself a few bucks and go back the stock bov. the issue is ur venting out the air your afm has already measured and this is making ur car run like crap doesnt matter what u do without some sort of air flow/fuel correction your cars gonna stall and be crap to drive. is it really worth the sound??
as I explained from the 1st post I'd like to have it for a weeks then back to stock BOV
just to experience it, Im pretty sure you did as well with your 1st turbo car...
so enough with going back to stock BOV
i know that already
just wanna try and make the stalling a bit bearable.
Cheers
oh ok then nah worries. yeah i had a blow off valve experienced your probs and took the thing off after 1 hour of having it on. But hey people buy turbo cars for different reasons. Best bet for you would be to buy a cheap safc from ebay it wont make the problem bareable it will fix your prob completely :) good luck.
Having a PFC will FIX the problem,
If you have a PFC and your car still stalling then your TUNER don't know how to TUNE the PFC properly. Apart from that, atmo bov will stall your RB25 as everytime you change gear, the stock ECU will dump a bit of fuel in and now there is no return air, all the suddem your car runs so RICH.
the reason no one ever bothered to solve the problem was that in the end we all realised how pointless it was to try to fix it. You can spend hundreds of dollars trying to solve this problem, buy this and buy that when you can simply solve it for free by putting the stock one back on. For most people, the novelty of the sound wears off after about a couple of weeks and the problem sovlves itself.
I don't know if this will help,but, i read a post a while back about this guy using his stock BOV, and having a vent to atmo. BOV just after the Intercooler pipe. ? you'd have to get a exhaust shop to install it for you and you should be alright. please correct me if I'm wrong.
good luck mate.
Aif
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
