Sydney Cruises
Assasin
 Share
Hi all,
I'm from Concord in Sydney. I drive an R34. I want to organise a drive this saturday night. Meet at Brays Bay Reserve Car Park, off Concord Road (in rhodes) 2 minutes from the DFO in homebush. No coppers there! Fits about 50-80 cars.
WHEN? This saturday night 9th June '07, being the long weekend. Meeting at 9pm.. Leaving 9:30pm.
COST? lol !!!!! - jokes A full tank of petrol (stupid prices keep going up!!!!)
Cruising through concord, haberfield, leichhardt, down city west link, over the bridge to McMahons Point (opposite the rocks, near Luna Park). From there we can go either Manly or straight up to Palm Beach or even Bondi.. Pending on how many cars we have.
Let me know asap if your interested. My msn is [email protected] OR just reply as per normal to this message..
Hope to see some of you then, before the skyline show on the 17th June..
Edited by Assasin
You guys cant go. It says Sydney Cruises. Concidering the weather it literally would be a cruise
BTW: Double demerits 8th to 11th June.
BTW2: I cannot go.
BTW3: I was referring to the R33 Boats. :)
Regardless of the weather its on... It'll be good anyways, as there will be a few patrols out and about.
9:00pm, leaving at 9:30pm from Brays Bay Reserve, near DFO Homebush.
I get my licence back after 5 years and 3 months, so I'm looking forward to a proper cruise..
Hope to see some of you there... =)
Edited by Assasin
damn..5 years 3 months.. what did you do..
that is such a long time..
isnt it gonna be storm these weekend
I think the whole winter season is crappy. But that wont stop this city of 4.5million people from going out. Come on guys, fire up! Nice car Mikyel! You'll like mine when you see it.
So far I got 5 people confirmed. One person might bring his mates down too (thats another 5-8 cars)
I lost my licence back in February 2002. Drive while suspended once, drive while disqualified twice, and high speed chase. I learnt the hard way! But I'm back and legitimate as of tomorrow!
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
