Wait a little bit until the RB26 unit is perfected for the 20. paulr33 has been working on it here on SAU and its all good from what ive read.
i'll grab the link for you, but will only be around $1250 for a brand new one, good value compared to the prices some peeps are trying to sell the discontinued FC's at!
Its already been done and run cobber, there are a few people running moddified 25/26 PFC to suit the 20.
Paul sold his loom to Mafia who has since gone on to getting it running in his car. It requires a few changed to run on RB20 but will be within the next few weeks once the new owner takes possesion ;)
JP you can buy a 25/26 PFC for $800-900 and i know someone else that can do the modification for you (shouldn't charge but if it is it wouldn't be much) which saves your brother having to fart arse around with it :thumbsup:
well surely there can't be too much to it, if its only changing the wiring thats no hassles at all for me, i just need to know what goes where. I have also seen another memeber on here running the 26 pfc, I have since sent him a pm but waiting for a reply. find that link haha
From my understanding there isn't a whole heap involved but it does require datalogit to make the necassary changes.
JP if you dont want to wait for a AP PFC then buy a 26 one and talk to Rob at Creatd Motorsports :P
CREATD Motorsports
67 Merri Concourse
Campbellfield
Melbourne VIC 3061
P. 03 9357 7663
F. 03 9357 7648
4WD Dyno Dynamics Chassis Dynamometer
I should have mine next week which has already been modified so u can try that first if you like :O
ok cheers ben i will give him a ring on tuesday and see what the go is, apparently the fuel pump needs to be rewired as the gtr pump goes from 7 to 12v ? and something to do with the afm part of the ecu, but not sure that was only a rough description i got of whats going on. will update the full story when i know, as its a very interesting approach in my opinion, I would be more then happy to get dr drift/the speed lab to tune it, but by buying a powerfc means i can get the tune adjusted easily here and also it becomes my resource to find out whats going on with the engine,
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
