Hey guys - got a problem to report - wondering if anyone can help out.
Last night me thinks - it's cold, 0.9 bar is going to be waaay safe so I dial it in and plant it in fourth. At this point a few things happened - which have happened before:
first boost comes up - ok, all good
then suddenly everything cuts completely for about half a sec - felt like I'd turned the key off!
then it cuts back in...
then it misfires around 5000rpm - which I'm guessing is the plugs and I'm hopefully going to fix that problem today...
the first problem of the engine/revs cut I'm thinking is the AFM going past it's voltage limit and shutting down.. does this sound right? what can I do to fix it? I've sprayed/cleaned it with heaps and heaps of electrical cleaner which didn't seem to make much difference..
Any ideas?
https://www.sau.com.au/forums/topic/17194-afm-problems-i-think/
Caminperth,
I had the same thing happen to me when I had my car at about 13psi while mucking around. It was fine on the dyno but as soon as it was on the road it would start to have the problem you described.
The guy told me that it would be even worse on a colder day due to the fact that there was too much air getting into the engine and the air/fuel ratios where not adjusting correctly on my stock ecu.
A SAFC would probably fix your problem, I have a simple Pivot air/fuel meter (1 universal setting) and adjusted it to make it a little bit leaner and it has fixed the problem for me.
I am no mechanic/tuner so it is just a suggestion ;)
Daniel
aidwin - as you said man - it's not the speed cut..
b005t - yea - i know what the speed cut is like and this ain't it. :rolleyes: and yea - am still running stock cooler...
adrian - could be - but it's fully intermitent..
bam - i wish i could afford the gtr!
daniel - i've got an afc and itc (old skool apexi fuel and ignition controllers) and that should sort out the fuel issuses at higher boost...
i fixed up the plug issue today - tho can't really try it out in this weather.. :)
still at a loss as to what it could be.. still got an inkling it's the airflow meter maxing out... will do it more when there's cold weather due to more air due to the density change... sound right?
Cam,
It's the boost cut/fuel cut. The boost controller has nothing to do with it, it's the AFM that tells the computer when it senses too much air flowing, which means too much boost, and it will hit boost cut, resulting in a nasty sudden halt to the car:D
You'll need to replace your ECU or get a fuel cut defender to stop this happening. It is worsened by the fact you have a stock cooler, and cold air is denser, thereby the AFM senses more air flowing:D
Hope that made sense (and is true)
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
