Hey guys - got a problem to report - wondering if anyone can help out.
Last night me thinks - it's cold, 0.9 bar is going to be waaay safe so I dial it in and plant it in fourth. At this point a few things happened - which have happened before:
first boost comes up - ok, all good
then suddenly everything cuts completely for about half a sec - felt like I'd turned the key off!
then it cuts back in...
then it misfires around 5000rpm - which I'm guessing is the plugs and I'm hopefully going to fix that problem today...
the first problem of the engine/revs cut I'm thinking is the AFM going past it's voltage limit and shutting down.. does this sound right? what can I do to fix it? I've sprayed/cleaned it with heaps and heaps of electrical cleaner which didn't seem to make much difference..
Any ideas?
https://www.sau.com.au/forums/topic/17194-afm-problems-i-think/
Caminperth,
I had the same thing happen to me when I had my car at about 13psi while mucking around. It was fine on the dyno but as soon as it was on the road it would start to have the problem you described.
The guy told me that it would be even worse on a colder day due to the fact that there was too much air getting into the engine and the air/fuel ratios where not adjusting correctly on my stock ecu.
A SAFC would probably fix your problem, I have a simple Pivot air/fuel meter (1 universal setting) and adjusted it to make it a little bit leaner and it has fixed the problem for me.
I am no mechanic/tuner so it is just a suggestion ;)
Daniel
aidwin - as you said man - it's not the speed cut..
b005t - yea - i know what the speed cut is like and this ain't it. :rolleyes: and yea - am still running stock cooler...
adrian - could be - but it's fully intermitent..
bam - i wish i could afford the gtr!
daniel - i've got an afc and itc (old skool apexi fuel and ignition controllers) and that should sort out the fuel issuses at higher boost...
i fixed up the plug issue today - tho can't really try it out in this weather.. :)
still at a loss as to what it could be.. still got an inkling it's the airflow meter maxing out... will do it more when there's cold weather due to more air due to the density change... sound right?
Cam,
It's the boost cut/fuel cut. The boost controller has nothing to do with it, it's the AFM that tells the computer when it senses too much air flowing, which means too much boost, and it will hit boost cut, resulting in a nasty sudden halt to the car:D
You'll need to replace your ECU or get a fuel cut defender to stop this happening. It is worsened by the fact you have a stock cooler, and cold air is denser, thereby the AFM senses more air flowing:D
Hope that made sense (and is true)
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
