for sale brand new jvc cd/mp3 player in box..... it is a very nice looking stereo.....
asking price $450 ono incuding post..... price drop $300ono posted via registered post
pm me with any questions
these are the specs on it
JVC KD-SH1000 Highlights
Power Output: 50W x 4 Max. MOS-FET Power Amp Advanced DSP: Digital 9-Band iEQ, 3-Band Parametric iEQ, LPF/HPF Crossover, and Time Alignment Advanced Multi-bit DAC BBE Digital High-Definition Sound Ready for iPod®* SD Card Slot DiAS Digital Tuner MP3/WMA Compatible with ID3/WMA Tag CD/CD-R/CD-RW Compatible 5V Line Output Level Gold-Plated Line Output Terminals (x 2 pairs) Gold-Plated Subwoofer Output Terminals with Level/Frequency Control Gold-Plated Adjustable Line Input TerminalsMotorized Slide-Out FaceRotary Encoder Multi-Control Multi-Function Wireless Remote Control Dot-Matrix Fluorescent Display
*In conjunction with KS-PD100
JVC KD-SH1000 CD Section CD Text Disc Name Registration Direct Track Access (1-12)* Random/Repeat Play Intro Scan
* Remote control only
JVC KD-SH1000 Changer Control Section
MP3 Control* CD Text* Disc Name Registration Direct Disc Select (1-12)** Random/Repeat Play Intro Scan* In conjunction with CH-X1500.
** Remote Control Only
JVC KD-SH1000 iPod® Control Section*
Play/Pause Skip/Search Random/Repeat Text Display
JVC KD-SH1000 USB Section
Direct Folder Access (1-12) Skip/Search List Access Random/Repeat
JVC KD-SH1000 Tuner Section
IF Filter 18 FM and 6 AM Presets SSM (for FM) Seek (Up/Down) AFNS/PNC Stereo/Mono Switch (for FM) Auto Antenna
JVC KD-SH1000 Amplifier Section
Source-Specific Volume Control Balance/Fader Control Volume Attenuator Max. Amp Gain Switcher Amp Defeat Switch
JVC KD-SH1000 Display Section
Switchable Dimmer Power Switch Standby Illumination
JVC KD-SH1000 General Section
Detachable Control Panel with Carrying Case Beep Tone Support COMPU Play Tel. Muting with CD Pause Function Power-Off Mode Eject Preferred Setting Mode
Edited by nissan23q
can you PM me an image of the face of the unit please. I 99% will take it.
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
