I did a search and couldn't really find what I am after.
When I start my car, there is a little puff of white smoke, and that's it. None when i'm driving or boosting, just on start up.
What would be causings this?
Also after that my exhaust has quiet a strong smell, it's had to tell what the smell is of - similar to burnt fuel, but this is constant.
I also had the car dynoed (not a tune or check, was just an open day dyno runs) and they said the car is runnin a bit lean.
What would this be from and how can it be fixed.
My Car is a 32 with a 26 conversion and remapped ecu.
white white smoke, oil, damaged turbo seal.
White steam smoke, blown head gasket due to running lean.
Possibly your injecotors are cloges, pump or fuel filter is on the way out
To test for head gasket, take it to a mechanic and do a gas analizer, this will tell you if there are any hudrocarbons in the radiator water.
With the radiator, I am getting a new thermostat put in and the radiator fulshed, cleaned and new coolant put in.
Is there another way to check if the head gasket is or on its way to being screwed?
If the head gasket is screwed, what's a rough estimate to get it fixed?
Edited by URAS_33
when u start ur car is it early in the morning when its cold?? probs just the hot air hitting the cold air and creating the normal mist which all cars get when its freezing. Its funny how many people i know who got all scared that theyre car is puffing out white smoke when this is all that it is. just a lil food for thought. It may not be all bad. with the running lean probs ur fuel pump.
A small amount of white smoke usually means the oil you're using is too light on start up.
Fuel smells nothing to worry about, probably just the seal to the fuel tank/pump, as it's known to perish on the r32 over time.
As for running lean that's bad... if you have a pfc or other ecu what knock reading are getting?
It just has the standard computer which has been remaped.
PFC is definatly the first on the cards and a good tune.
Yeah white smoke / steam is really faint and does disapate straigh away. I guess coz I'm new to the RB26 (only had a 25 before hand), I'm sketchin about every little thing thats goin on.
I also get white smoke on cold morning starts but i hope its due to LatinR33's explanation :P
Will have a proper look tomorrow morning if it lingers around or just disappears
Read from a site.
could be antifreeze when it is being burned it has a sweet type of smell and tends to dissipate in the air rather quickly
Sometimes when the head gasket goes it will produce a passage for the antifreeze to pass from the capillaries into the combustion chamber.
Answer 2
If the exhaust billows white smoke for a few seconds when first starting the engine after it has been sitting for a while, such as overnight, and then runs normally, it could mean that the rubber valve stem seals have perished - especially if the vehicle is a few years old and has done over 60/70,000 miles.
Another clue is: does the exhaust smoke smell like fresh, rather than burnt oil.
On cold engine starts, especially, the ECU will momentarily run a rich mixture to get ignition going, then thin it back to normal once the O2 sensor can get an accurate reading. The puff of 'smoke' probably has a sweet smell and would contain a small amount of poorly combusted fuel, some uncatalyzed exhaust, and likely a bit of condensation.
Remember it this way--if the white smoke doesn't go away, THEN you have a problem. If it disappears after a few minutes, it's just water vapor. Part of the chemical equation for the combustion of gasoline includes H20.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
