The worst thing about the Stagea is it is over weight. I have been thinking about putting it on a diet
Basically if say a 100kg can be removed, if that is possible it would impove the power to weight ratio by about 10% on a 300kw at engine car
Things I have already done are
1. 34 GTR front end with alloy bonnet and fibreglass guards much lighter than the steel ones
2. R34 GTT front rear brakes with alloy calipers, not sure if the wieght saved on the calipers gets out weighed by the extra disk size?
3. Manual conversion from tipronic auto?
4. 34 GTR 18x9 forged factory wheels, verse cheaper cast rims 17 or 18's
5. 3 inch s/steel exhaust with with split dump verse factory cast dump and steel exhaust
6. larger FMIC and alloy piping verse factory side mount and some steel piping?
Other things I have thought of that will help are
1. 34 GTR front lower control arms are alloy and I think they will fit
2. Alloy body coilovers like the zeal ones. I had a set in my R33 and were much lighter than steel ones
3. Other alloy suspension arms and parts like caster and camber?
4. Are nismo suspension lighter aswell as being stronger?
5. Titanium exhaust
6. Alloy radiator verse the factory one?
7. No extra stereo bits like subs or amps
8. light weight front seats
9. Carbon parts?
10. Half a tank of fuel and no water in washer bottle. . just kidding
Bascially want keep the car like factory, so no noise reduction by removing sound deadening etc
and to stay relative legal ie no carbon panels etc.
I assume some of this would have been covered before esp for race cars, but give me your thoughts and ideas
things like take out the roof lining, replace stnd front seats with lightweight race seats, swap glass windows to plastic, remove rear seats, drop out the 2.5T engine and replace with 600cc Capucinbo engine (lol joke)
dice the fast glass and put manual winders in. That would be good for close to 10kg's per door - but it would mean sourcing the winder mechanisms from a much lower spec car.
I can definately see where you are coming from Darrin, and i think some of the things are definately a good idea for a number of reasons not just the weight loss.
In my opinion things like going for an alloy radiator is better for keeping the engine cooler especially if you are going to go for a twin or tripple core but i really dont believe that you will save much weight if any on an alloy radiator. Think about it standard radiator has plastic end tanks anyway which are extremely light weight and the actually core itself is alloy i believe they are pretty darn light already.
Upgrading brakes are one of the best ideas on there not only the fact that you are shedding a few kg's but are also making the car safer.
I dont belive that going manual would make the car lighter at all, considering you have to consider clutch, pressure plate, flywheel, and then the gearbox, plus all the master cylinders slave cylinders pedal box and pedals change the handbrake etc.. I know i am taking this to extremes but still there is probably added weight going manual.
Mind you i would have a manual over auto anyday
If you have had the tailgate struts go you will know how heavy the rear gate is. If you could find a light weight version of that you would save 50kg.
Ditch 4wd system, run a 33 GTST box and have some fun.
(kylie and i have already copyrighted the idea of a stagute, so ner! :P )
Only one problem with that Mitchy - its already been done (well, in a single cab anyway)
the nismo arms arent lighter, just better bushings from what i observed
your largest weight loss would be to remove your AC and all components
then take out your seats, front and rear, and carpet
get some dry ice, and hold it on your sound deadening
then chip it away
take out your spare
wiper resivoiur
loose all your heatshielding under the car
change to hollow sway bars
tubular links
wheels
CF hood
FRP bumpers, skirts
sunroof eliminators
Remove front and rear crash bars
replace with aluminum ones
i can keep going, it all depends on how determined you are
then chip it away
take out your spare
wiper resivoiur
tubular links
wheels
CF hood
FRP bumpers, skirts
sunroof eliminators
If someone was really that worried about having a light car why buy a Stagea, In all seriousness if you want a fast sports car dont buy a stagea.
no need to make it lighter ITS A WAGON for a reason it will unfortunately run 15's all day with the air on flat . But i have a trophy that states even thou they might not be quick they are consistent and I being runner up is no same against evos wrxs and the odd 32 33 !
You are probably 40kg's on the way with the front end conversion.
Then go;
* Forged alloy rims - 15kg
* carbon tail shaft - 10kg
* Ross alloy engine damper - 3kg
* Light weight alloy pulleys - 2kg
titanium exhaust - 10kg
* lightweight flywheel - 5kg
* electric fan to replace clutch fan - 1kg
That's around 86kg off and the ones marked with * increase the response of the car and improve the accelleration (quite significantly).
The best thing is that your car will not have suffered anything for comfort.The car will accellerate, stop, turn corners better and even improve milage without the extra wear and breakage associated with an equivalent power increase.
If you are really keen on getting the most out of the car some of these things will cost you a tad but, it is much the same direction taken by the likes of BMW and Porshe to extract the best from the car as a total. The carbon fibre tail shafts are now a standard feature on RX8's and the 350z 'track' for instance.
Edited by rev210
Then go;
This is the best answer so far
You have listened to what I asked
Not to loose factory comfort, but increase performance
The car is remain as the "family 300kw wagon", not a noisey light weight race car
As for cost, I have spent more than $20K in mods, so what is a few more dollars to make it better.
Out of curiosity - are S1's or S2's heavier? Obviously different options make the weight vary, but I'm curious if theres anything that there were any significant changes between the two models that affected the overall weight of the car?
Then go;
That's what I was gonna say, Darrin - everyone else has mentioned removing carpet, air-con, seats, etc but you specified that you wanted to keep most of your creature comforts to use as a genuine family car...
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
