hey guys just wondering about the law in victoria for mounting gauges.
i have just bought a boost gaauge and was wondering what the law is on these?
had a read and there were alot of different responses from different states.
whats the law in victoria?? can i mount it on the right hand side in the corner? or is that illegal?
thanks in advance
any pics of other peoples would help.thanks
https://www.sau.com.au/forums/topic/171998-mounting-boost-gauge/
No mounting on the pillar in VIC.. from memory it's because of potential head impact/trauma in an accident. Or maybe it was because it can block field of vision, can't remember which :O Anyway if a cop spots it you're likely to get pulled over.
We put gauges in a triple gauge holder/plate from onautos.com.au and put it in the DIN panel in the R32. Don't know if they still sell them though.
You can also buy cups.. but it's a really stupid law.. something like.. Nothing can be mounted any higher than 30cm from the BOTTOM of the dash (according to TMU). So I shoved mine in the right side corner and it's below the top line of the dash either way. Haven't been hassled for it (dbl sided tape is good)
Actually you can kinda just see in my avatar.. the line of the dash starts to go up over the speedo cluster etc. Hope that makes sense, gotta run out :P
No mounting on the pillar in VIC.. from memory it's because of potential head impact/trauma in an accident. Or maybe it was because it can block field of vision, can't remember which :P Anyway if a cop spots it you're likely to get pulled over.
Is that another Vicroads law I didn't know about?
I have A-pillar gauges at the moment (two of them) and have been wondering if I need to remove them or not.
So they are illegal in Vic? :)
Yeah, gauges in the A-pillar would be illegal and it's something to do with being in an accident and your head hitting it.
I think the law was that, nothing can be installed higher than the highest point of your steering wheel. Let's say you put your steering wheel to its maximum height, the top of your steering wheel is your limit.
Again, this is just what I've heard so.... :)
Cheers,
Adam
How can you not know about them?
They are all clearly listed my friend :P
http://www.vicroads.vic.gov.au/Home/RulesS...rdsInformation/
Read each of the relevant ones to the mods your talking about.
In this cause pillar gauges come under VSI: No. 8 & No. 26
They are all clearly listed my friend :)
Well if its not obviously listed here:
http://www.skylinesaustralia.com/forums/in...howtopic=156269
Then I'd probably miss it, that threads changed since I read it so it may be there now.
I didn't think I'd need to read the Vic Roads website after I bought my car from Japan but clearly I should have.
I will take a look at the Vic Roads website and I'm looking at buying from http://www.mearcat.com.au/
Regards,
Gareth
:cheers:
Ermm... It is clearly listed in the second post dude. have you read it?
:sorcerer:
Stop being so technical :rolleyes:
I meant that I read the page not all hyperlinks off the page, if i did that then I would never be able to stop reading :thumbsup:
But I'm reading it now.
After R31Nismoid's hint I finally found the information on page 8, VSI26.pdf from Vic Roads (thanks R31Nismoid).
To repeat the Vic Roads guide:
"Apart from any pillar or other part of the vehicles structure or fittings, there must be no internal obstructions to a drivers view through the swept area of the windscreen, to the right of the driver's position or 60degrees to the left of the drivers position, except for the area outside the primary vision area."
Ok, so its plain illegal under "Repairs and obstructions to view" in the Vic Roads rules.
Anyway, I'm looking at buying some gauge pods now to make the car more legal :rolleyes:
Regards,
Gareth
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
