Can anyone give any suggestions as to what could be the cause of the following problem on my sons Skyline R32 RB20 Single Turbo.
Car has a slight splutter/misfire when at operating temperature but not when cold.
Spluttering/misfire at constant motorway speed ie 80, 90, or 100 but as soon as you accelerate it evens out smoothly only until you come back to a constant speed then splutter comes back again.
We are at a loss, Can anyone shed any light.
Thanks
Tony
https://www.sau.com.au/forums/topic/172003-missing-problem-r32-rb20/
first id try playing with ur igniter module, pull the plugs around when its missing, if its not that pull the plugs out individually in the coilpacks, eventually ull source the cylinder having the problem. chances are its a coilpack problem, if not check ur spark plug etc.
