i was just looking up specs on r33's the other day and i noticed that some came with a 5spd auto instead of a 4spd like in my car. i also noticed this is only in N/A cars, namely the GTS25 TYPE G and TYPE G SE sedans and the GTS25 AND THE GTS25 TYPE S coupes. im assuming they are series ones, since there is no mention of any of these post '96.
now to get to the point. is it feasible to chuck one of these in a turbo model coupe of the same time frame? i have a auto type m, and purely in the interest of fuel economy i am considering this. few q's to guide discussion:
1 how hard are they to find?
2 are they different in any way to the turbo slushie? difference b/n sedan and coupe?(dimension, weight, fitment etc)
3 cost wise is it cheaper or more expensive than a manual conversion? (guessing cheaper)
4 will i have to change my ecu to run it?
thanks fellas.
btw i got the model info from here
https://www.sau.com.au/forums/topic/172024-5-speed-auto/
  • 1 year later...
I've heard of it before in r33s, its probably quite rare. I also read somewhere the trans is physically longer too so you will need a shorter drive shaft. THe only trans i've found that "seems" to match this description is "RE5R01A or RE5R05A" - most likely the ones in the r33s - there is also a "Jatco JR507E transmission - but I think this is for later cars like the 350Z"
Unfortunately all I can recommend is more googling in regards to your conversion - I have no more info :(
https://www.sau.com.au/forums/topic/172024-5-speed-auto/#findComment-4255914
i had one in my old 4 door n/a, it has D 3 2, instead of D 2 1, if that makes sense. (so i figured it was)
(it was annoying doing a burnout cos id chuck it in 2nd being the lowest and it would spin up first, then change to 2nd once the revs got high enough and being a n/a it would just bog down and go fail.)
the thing is id count the gears and i could still only count 4 + the over drive :s weird.
i wouldnt really bother, my old auto box was shit house anyway.
although cruising at 110 with over drive on it would sit pretty low from memory compared to my manual. 2000-2500rpm lower ruffly
but yer thats all my experience with it..
https://www.sau.com.au/forums/topic/172024-5-speed-auto/#findComment-4256286
  • 4 years later...
You won't make it work with the 4 speed TCU. Would need something that can handle the extra solenoid(s).
I should point out that the NA autos (and probably the 5 speed in particular) probably won't hold up to the torque of a 2.5 turbo for very long. The 4 speeder is a marginal enough proposition behind a stock 25DET, let along a boosted up one (and how many standard ones are still running around?).
https://www.sau.com.au/forums/topic/172024-5-speed-auto/#findComment-6716153
Yeah that's what a few people have said, there is a few standard ones around still but people want way too much for them, rather do a manual conversion for a few extra hundred, but just a daily do wouldn't mind keeping it a auto for now but the gear ratios look pretty good where 1st in the 5 speed is 3.8xx and 1st in the 4 speed is 2.5xx and then top gear in each us 0.69, as far as I can see tho the wiring for both are the same but happy to get a ecu to get it to work but can't find any
https://www.sau.com.au/forums/topic/172024-5-speed-auto/#findComment-6717359
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
