Engine freshly rebuilt 4000km ago, ACL Forged Pistons, new rings etc,
2 New N1 Turbo's
New rear tyres
Apexi AVCR boost controller
Engine Warranty: 40,000 km or 2 years
Service History up to date
New Motor, Clutch and Tyres. Full Overhaul
Charcoal exterior, grey interior
Interior fair, small rip in drivers seat which seat covers could disguise
Good condition for age with normal wear and tear
Payment in full by bank cheque or bank deposit
Local pick-up preferred, however will arrange shipping throughout Australia at buyers expense
Buyers are welcome to test drive and/or have a full inspection undertaken
FULLY SERVICED THIS WEEK
Genuine quick car!!
Only asking $18000 FIRM
I've moved to NZ and Its gonna cost way to much to bring my pride and joy over here so It must go to a good home!!
Cheers
2 New N1 Turbo's
New rear tyres
Genuine quick car!!
Cheers
wouldnt consider a swap? PM me plz
Hi Tom
What are the two pieces of tape covering on the boot? In the photos it appears to be deliberate holes, but I can't think what they would be for.
Thanks
Michele
Hi Tom
Thanks
Michele
The car came with a very ugly drift wing attached so I took it off and there are 2 small holes in the boot.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
