Hi guys was wondering if u can help me with this problem
i have a 5 puck ceramic excedy brass button clutch.. its only 8 months old.. and now its slipping any idea... my car is only making 176 rwkws and the clutch is rated at 300 RWKWs.. the clutch relaese point is now about 3 mm from the top so i barely have to push the clutch in to dis-engage the clutch from the flywheel.. and when u engage the clutch again.. its like its not fully engaged back onto the flywheel..
is there a manual way to reset the clutch relase point ect.. like someone once told me you can adjust the throw out point from the clutch pedal up top..
any ideas... i cant book the car back in for 4 weeks at the place i got it.. and im just getting the shits.. spent almost 1k on a clutch and its rooted already.. i hardly even slip the clutch just take off liek your supposed to with a brass button..
Any help would be muchly appreciated
you can adjust the clutch master feel at the top of the pedal there is a pin going thru the clutch pedal held in place with a split pin. remove the pin, and you can screw the saddle in tighter or looser depending on how u want the pedal...
be warned the pin is an absolute bastard to get back in :)
you dont need to remoove the pin to adjust it, just loosen the locking nut on the fork that goes over the pedal. p.s i wouldnt be playing with that stuff unless you know what your adjusting, it adjusts the freeplay. yours could be incorrect causing the pedal to be always engaugeing the clutch and therefore wore your clutch out prematurely.
hey
i have one of these exact same clutches and its less then 1500 kms old... took it out to mallala for drift prac and before i even got out to the track on my way to a mates workshop it just all of a sudden started to slip while IN gear... in 4th at 3000 rpm about 80kph i would give it some throttle and it would just start slipping!!
gave it a bleed, didnt do much at all.. went out to the track and needless to say it was pretty useless.. im pretty disappointed with the clutch, considering i only JUST bought it.
not even making much power either... about 170 rwkw
nar. brassies ware out pretty quick. especally iff slipped
yerp i had one in when i bought my car from the previous owner fitting it.
I had to remove the driveline to fit my 3lt and while the clutch was out i replaced it.
Simple fact is buttons suck for a daily driver, or carpark shopping. Anyone who uses em on the street will make em slip soon. This is like the 10th person ive heard recently complain.
I also noticed they burn out the std flywheel as well which is a bitch, but lucky i bought a os twin to replace it with (flywheel incl.) The pedal feel is back close to stock, it doesnt slip or shudder from carparks, and will handle anything i throw at it.
ive had 5-6 puck clutches for years and never really have had much drama;s with them til this last one... its just useless and it has had bugger all driving done on it. it started slipping from the word go really.
totally agree that brass clutches are not for the street. They not only wear out the disc but due the the metal in it, the flywheel and also the pressure plate.
If it started to slip so soon it could be a hydraulic problem pedal may be still engaging even though its all the way out.
On the track though they can hold a lot more than an organic disc
exedy copy clutch was what I heard it was Simon that true?
didnt even know you could get copy clutches
its not a copy, but rather an exedy disk and seco pressure plate....seco being owned by exedy, so technically its all the same.
    • Hmm makes things tricky then.  I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.  But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.  If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?  Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
    • Ok so I will not defend my naivety. I regularly feel like things look easier than they are.  As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
    • If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.  I've seen professional welders do similar but easier repairs and still end up with warped panels.  It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.  Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.  Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
    • I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.  I'd prefer some ugly metal fab than anything weak.  I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
    • Ok, thats a good starting point.  So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right? Before we look at other options, how confident are you welding?
