No Driving For A While! Not No More!
Guest Joeyz
OMG Joey :O:(
Thats such bad news....so glad you are ok tho
It is hard to drive these cars in the wet at times, I know I have been taking it very easy for that same reason..
Hope you get her fixed up soon :P
*hugs*
Jess
Thanks Jess.
I hope it dose not take long to fix it cause i feel lost not driving. I was supposed to drive to canberra this weekend for my uncles birthday but had to go with my parents :) .The boot is pushed in maybe about half a foot or so and the drivers side from the door back is buckled so im praying to god it wont take long. :(
  • Replies 49
Posted Images
unfortunate luck there Joeys - gotta be real careful in the wet with these cars!! Also decent tyres with good tread depth makes a world of difference. I minimise the amount I drive in the wet because mine are getting down a bit - been trying to find some rims in better nick but failing that will just have to bite the bullet and get new tyres.
that vid is great :)
R31's drift hard in the wet. especially with a locker :)
find myself wondering whether a 1.5 way in my car would be a good compromise between sideways and driveability.
My car got towed to Just Cars Assesment centre at Condell Park today for their final assesment :)
Did anyone see it?
It was a sad moment to see. I only hope it turns out as good as it once looked.
I'm sure it will dude! they can work wonders these days, it's just a waiting game now!!!
My car barely makes it out of the garage these days because I'm a little paranoid about getting hit again!
Guest Joeyz
Hi all!
Just got word from Just Cars and the car will be getting towed today form their assesment centre at Condell Park to Senator Smash Repairs at Rooty Hill/Glendenning to be fixed. Spoke with them and should have the car back in a month or there abouts. Yeah!
Has anyone heard about this smash repair before?
Joe :)
Guest Joeyz
No courtesy car for me, if it was an accident with another car involved and i was not at fault then yes one would be provided. In this case no no.
So i will be looking around for a cheep car. Sorta been looking for one so i don't have to drive mine every where to keep km's down. If anyone knows of one please PM me.
Joe
Guest Joeyz
Hi all. Can someone answer me this question?
My car is getting repaired and i would asume that the battery has been disconected during te full tine of the repair. Will the computer loose it's memory in regards to the tune or not :D ? Will i have to get the car tuned again? :(
Joe
    • Either the WG is reaching full opening, or it is not. The "it is not" case could only occur if there was not enough time available to swing the valve fully open during that boost event. I would consider that to be unlikely, as this is a commercial product that is in use elsewhere, so it really should work. But in your case, because there is definitely SOMETHING wrong, it should not be assumed that things like that are working as they should. You should put a video camera where it can see the actuator (if at all possible) during a run to see how far it is moving.
    • I think you're mostly on the ball there. With the straight gate, I suspect the weight of the spring will determine how quickly the gate can close, when not run with active pressure drive on both sides of the diaphragm. Otherwise, with drive on both sides of the diaphragm, you could almost go without a spring at all, only needing one to make sure that the thing was actually closed while completely off boost and not having pressure available to drive it closed. Butterfly valves have mostly symmetric loading when there is flow going through them, meaning that the gas hitting the upstream part of the blade is balanced by the gas hitting the downstream part of the blade, which means you don't need actuator torque to overcome any non-symmetric flow induced loads. But the gas flow does impart a purely normal load against the shaft, which transfers into the bush/bearing at each end of the shaft and does increase the torque required to make the shaft turn. Only a little, but it is there. I have no feeling for the amount of force involved in a WG application, but it certainly could make an argument for a decent spring weight being required. But all of this is just peripheral to the actual problem here.
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
    • lol nice, I wouldn't worry about sanding back the filler to check for rust then. Yep very much a thing. Personally I don't do the panel beating, its very easy to have a panel beater sort that out for you. If they aren't doing any prep work the actual panel beating generally doesn't take long at all.  Have you taken before pictures before you started this project? I'd be keen to see the before and afters when you're done.
    • Some good discussion in here, for the most part I can't really add too much to it - thought I'd add some notes to the datalog screen shot that probably aren't news to anyone but a good prop... this is assuming 25psi-ish should be the boost ceiling given the first post refers to 23psi.   To state the obvious, this issue seems super weird.  Turbo speed seems pretty lethagic to build, like the turbo isn't getting as much drive as it needs - and it doesn't help that wgdc keeps rising AFTER boost target then completely shuts duty at a point, which in theory should have the straight gate dump heaps past the turbo and funnily enough causes the huge drop off.  It seems like pretty blunt boost control tuning but I'd not call that the primary issue, so much as possibly not helping the situation. I'm curious, what does a pull look like with purely mechanical boost control?  Like purely wastegate?   There are things in this log and story that make it sound like there could be a significant restriction in the intercooler piping or something - but then it's also overshooting boost target which is NOT what you'd expect with a restriction.   I can see where people are coming from with the non-linear wastegate bypass (not that any valves are linear for this kind of thing), but it still doesn't make sense that it can't hold <20psi on a 12psi spring.    Have you, or can you try measuring pressure pre-intercooler?  Be pretty interesting to see what's happening there vs in the intake manifold - sorry if I've repeated old ground, I've kinda skimmed over but I could have missed something.  In terms of comments regarding the wg spring being closer to boost target, I haven't used a straight gate but part of the reason for having close to wg target is about fighting backpressure as well - I might be wrong, but I'd have thought that part of the point of using a butterfly valve like the straight gate does you actually don't have to resist pressure at all, on EITHER side of the gate.   It shouldn't need too much leverage to start opening, the spring being more to do with where it triggers opening as opposed to resisting boost & EMAP, though smarter people can correct me if I'm wrong there.
