Hey everyone, im getting close to re-assembling my Rb26 and have my heart set on the HKS GT-SS turbo kit. I've heard mixed results comparing them to rebuilding my stock ones through Aaron at sliding performance. Yet to ask him for his thoughts. Some say the rebuilt ones are only slightly laggier than the stock items and have potential to make more power than the HKS GT-SS turbos. Others say the response from the GT-SS turbos is phenomenal. I like the sound of the ultra quick response the GT-SS provide, however I do want a pair of turbos that will perhaps one day provide me with big power as the bottom end is built quite tough. Can some of you guys who have first hand knowledge tell me what you have found with either combination. Keen to hear about power i could expect from either setup and response of the two.
Many thanks,
Deren
https://www.sau.com.au/forums/topic/172060-rebuilt-bnr32-turbos-vs-hks-gt-ss/
Change the turbos when you rebuild it then :P
Its only going to be another 2.5k on whats going to be nearly 5 figures anyhow.
So GT-SS for now, and if you think its not enough power or whatever, change when you rebuild.
Thanks guys, the car has been off the road for about 2 years now as ive been rebuilding it ground up. See my restoration thread.. Im about to re-assemble the engine so i was starting to get serious with what turbos i wanted to use. I know the obvious comparisons you can make between the two ie: one is roller bearing the other is not etc. However i wanted to hear some opinions of guys who have actually sampled both.
Deren
Garrett 2860-5's FTW check out "The Alchemists" dyno results on here somewhere he changed from GT-SS to 2860-5's after like 3000 k's or so spool up almost identicle but made more up top,
from memory wasnt an over the top built motor either just poncams etc, it a few beers to late for me to be to accurate
I just brought a pair offa slide and the cost is better than the HKS tax too with most importantly the possibility of a little more power to boot. :)
Ahh very interesting. Will that be a direct bolt on replacement? I've had a 'direct bolt on' from garrett before on a s13 silvia (2560r) and it took much work to fit it including a fair bit of fabrication. Thats something i dont want to have to do on my car. However from what you said it does sound interesting.
Yeah i know i can get GT-SS from Nengun for $2700 delivered, but thats even better. However i am quickly beginning to prefer these Garrett 2860r-5. I like the HKS kit because it comes with everything i would need to fit them. From previous experience buying/fitting turbos from garrett you are supplied with poorly fitting gaskets not to mention the fabrication i found necessary to fit the turbo. Can anyone tell me first hand if this is the case with the 2860r-5 turbos. Also could anyone give me an upto date price on them?
EDIT: Sorry missed that price Ronin. I guess the advantage i'll have is i'll be building the engine/fitting the turbos on an engine stand so it wont be too hard to get any minor changes made. I just dont want to have to modify inlet snounts or anything like that. Anyone fitted these suckers themselves and can tell me what mods are needed?
Edited by Godzilla32
Im driving a 34GTR and with the standard ball bearing turbo's reconditioned once, i was able to get 385awkw.
With the GT-SS now, im doing 472awhp at 1.6 bar.
For me, the standard turbo's felt more responsive although it could be due to the tuning?
Im not too sure the GT-ss's sure feel laggier as compared to my standard turbo set up but still very responsive and comes very fast wheh compared with other turbos.
I think the apexi AX75? or AX67? sumthing like that. A twin set up as well. Ive tried it on a friends car with the Tomei Derive RB28... Awesome turbo's.. Not much lag and very responsive as well..
just my 2 cents. Hehe
I see, thanks for that.
Im tied between the HKS GT-SS turbos now and the Garrett 2860r-5 turbos.
I cant choose one. The garretts arent in a kit and will need gaskets and some modification to the oil returns but i can buy them from australia (no possible taxes). They look just as responsive as the GT-SS turbos and look to have the ability to make more power aswell.
However the GT-SS turbos are in a complete kit with everything i need to fit them, only marginally more expensive, and a proven responsive package, but will buying these from nengun for about 2700 delivered incur me duty tax? Anyone got any knowledge on that?
Many thanks,
Deren
hi Deren,
i am in the same boat at the moment deciding on what to upgrade to. i am leaning towards the 2860R-5 because they seem to fit the response/power balance i am after. also they are currently only $2450 del from slide :P i have a friend who imported some HKS 2530 through greenline a while back and he tells me that he did pay a tax on arrival at customs, about 10% on top. i know what you mean about the gaskets- i have been quoted roughly $300 from nissan for everything required. so if you factor that in they end up very similarly priced....
hope that helps, Mike
Cheers Mike, its a tough call i know :D Im thinking to go down the 2860r-5 path also. One reason being i had the head and turbos off not long ago and can reuse most of the gaskets. So that leaves me with some elongated holes on the oil return flanges. Hopefully nothing else pops up causing problems. I didn't realise they were $2450 from slide, thats even cheaper! I think im sold.
Deren ;)
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
