Well i went for bit of as cruise today out of town to Rotorua, and on the way home i had one of my rear tyres blow out! Pretty scary as i was on the open road doing 100km/h. When i eventually got the car in a straight line to stop i inspected the tyre, i saw the WHOLE inside wall had blown out from the rest of the tyre!!!
The tyres were bout 6months old and had a fair amount of tread, anyone got any ideas as to what would cause this? The tyres are Nankang NS2 225/35/19.
https://www.sau.com.au/forums/topic/172083-tyre-blowout/
what size wheels
if its a 9...id say that you had an improper alignment, which irregularly wore one strip of the tire, where it blew out and separated
ive seen it happen before
if its like a 7 wide, id say bad luck
but if you hvae a streatched tire and improper alignment, it is unsafe
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3169694
Has the tyre been slightly under inflated recently. Being just a couple of PSI down on a low profile tyre will chop out the internal side walls very quickly due to the constant flexing and squashing.
Check the inside of the other sidewall when you get it off to see if it has any rubber flaking off it
225/35/19 i would keep that size tyre at least 35 psi
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3170218
id reccomend 38-40 personally becuase it has a stretch on it
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3170398
Join the club mate, I had the exact same thing happen to me, except I had a trailer full of furniture on the back. It's because of the camber on the rear wheels, it wears the tyres unevenly. If you've lowered it get adjustable camber arms, otherwise a camber kit can fix it.
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3170653
and dont forget, when you lower it, it also messes up the toe
horribly
camber wont wear tires
i ran my car (the 180) with almost 4 * of negative camber for 6 or 7 months with no irregular tire wear
the Toe is drastically effected by the height of the car on the nissans rear setup.
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3170733
Both Humble & l have blown rear tyres exactly the same way ... and the same shitty tyre brand too.
According to my guy at tyre centre its more to do with the tyre's than camber or toe. They're just cheap tyre's that are known to blow quickly.
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3171546
horribly
i know guys that have ran -5 to -8* of camber on their rear wheels on large VIP sedans...and no irregular tire wear after a year.....
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3172641
Without getting into the argument of camber and tyre wear, the above qoute is correct. I went from -2deg camber to +2deg when I installed a double camber kit. (theory was that each single kit added only 0.75 deg camber) At the same time the toe went from -1deg to +10deg. The car was downright dangerous to drive, especially when you hooked into a corner and the weight transferred to the outside wheel - which was trying to steer the rear of the car around to the front.
The problem comes from the toe adjuster arm which sits in the lower/middle part of the suspension control arms. The camber kit pushes the top of the tyre out, so the toe adjuster arm effectively pulls the rear of the tyre in.
Still, I cant see how this would cause a tyre to blow. Tyres can wear through to the first belt without too many worries.
Plus, I always run 40psi..just my 2 cents worth
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3172999
How can you say that WON'T cause irregular wear?
Your tyre spends 80% of it's life running on one corner.
you have to understand
a normal tire lasts what 40,000 Miles? so thats almost 70,000 KM i think (i dont know the conversion off hand)
If after 10,000 miles there is no uneven wear, its normal
it would take 15-17,000 to show heavy uneven wear on a hard compound tire
ill show you, i am ordering my airride friday, and ill keep a report with huge amounts of camber and tires wear
https://www.sau.com.au/forums/topic/172083-tyre-blowout/#findComment-3174622
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
