  • Replies 57
So they do an emmsions test, or just check to see if the cat is hot?
I might just make some metal restricor plates and steel wool and that should quiet her down nicely.
ALso im not sure whether a strut brace is illegal, however i might just take it off so they dont pick on it.
Guest Miss_Nismo
Originally posted by CheekyR32
Pleaaaaase dont remind me about regency. nightmare
to pass my windows ALLLL the tint had to come off. (even factory) and to get my exhaust through I had to stuff a shitheap of steel wool in there and make metal plates at intervals through the pipe .  Not to mention all the other parts that had to come off which basically left it a rolling shell... They obviously are not too bright.  How can a 4 inch exhaust make 40 db ? I'll show ya!  I then took a day off work and waited 6.5 hours while they had the nerve to tell me to hurry up.
Regency change the rules practically every week so I would not be too fussed about it guys.
hahaha didn't the steel wool catch on fire as you drove off? bahahahahahaha :bahaha: :bahaha: :bahaha:
Guest Miss_Nismo
yes it did.
Time of the month mel? rofl.
nah just thought it was funny, not being nasty at all chickito
don't worry when they took my car for a test drive at regency, the airbox was in so tight it squished the pipe up too much and when the car hit boost it wasn't gettin enough air, hence, the car was almost bunny hoppping down the road and the regency guy is just looking at me like, umm, what the hell. I'm like " uh yeah it hasn't got much petrol in it"
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
