Wires In Boot (r32 Gtr)
Hello guys fellow reader new poster here! I have brought a GTR a few months ago and now i have a major problem. There is 2 lights on the dash which are the 4WD and ABS lights. There is plenty of threads about this problem but as far as i know but they all point to the box in the back (HICAS? or ECU?) with lights but i can't find the lights. Now when looking there i notice that some wires are disconnected and looking quite wierd. If you could point me in the right direction that would be swell!
I have attach pictures of the wires that are of concern!
Cheers again.
I can't tell you straight away what the connectors dangling down are, but in your second picture, on the very edge, there is a dark circle on the module. That is where the led lives. If that helps.
James.
James.
OK cool thanks!
Oks guys a looked at the little box with the life and i get 13 flashes! G-Senor right?
According to the good book error code 13 is a fault in either of the two fore & aft G sensors.
But as has been said you need to check those wires to confirm their function & to determine whether or not they have been mucked around with.
Edited by djr81
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
