Guest sir_GTR
Hey guys,
I'm not sure if this topic has been discussed b4, sory if i'm repeating it
Anyway, I went to get 2 quotes for a full exhaust system;
1. N1 front pipes
N1 Cat back system
Mid pipe custom made with Cat 3" h/flow
(stainless steel muffler + tip only)
$2300 fitted
and 2. JunBL
3.5" custom dump & Hi flow cat (mild steel)
JunBL cat-back with 4.5" tip (s/steel cat back)
$1600 fitted
The question is?... is it worth the extra $700$$$ for the N1 exhaust??? or just go for the custom made JunBL???
Will it make much difference in performance? or am I just paying for the name?...
Any feed back is appreciated :D
Andy
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/
Originally posted by sir_GTR
Hey guys,
Andy
Sometimes theres actually may be more information posted
previously about the topic then you may get in your thread. I'm
sure everyone will be happy to add to an old thread and give
updated info. Not taking a stab at you Andy, I've done this
before and found there was heaps more information posted
previously. Maybe worthwhile.
Have you considered other exhaust eg the HKS Super Dragger? Are both front/dump pipes mild steel?
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-32731
Guest sir_GTR
Joel you bastard :cuss: :cuss: :cuss:
Yah your exhaust is certainly a "sleeper" alright..
darn you car is fast...i cant believe it...I launched the same against the VX SS, but you're like...wat the ***, whats he still doing next to me... ARRRRR...
Maybe I'd need to launch 7000 next time... but then by friday, i'd have full xhost and K&N... it will be different...
I actually went to dtperformance.com.au ...left out www.
I'll check the site out now... thanx mate
Cheers,
Andy
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-33068
Sir GTR, I was just about to mention that...
JunBL has nothing to do with "JUN Auto Mechanics" in Japan
It's dodgy Korean gear that I have seen the tips just drop off...yep a mate bought one and after 12 months the exhaust tip just fell off, turns out that it just rusted off, interesting for a stainless muffler?????
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-33612
after having gone thru a few different mufflers makes on different cars myself plus my mates' cars, i'd defn only choose jap names like apexi, hks, trust, fujitsubo, tanabe etc... they've been proven to flow very well and yet keep the noise down... where front end pipes are concerned, the engineering involved results in well designed and constructed bends... if ur local exhaust shop can make up good front end piping for a good price, then i'd recommend that plus a jap muffler... brands like junbl and chitose and whatever other non jap made ones that have jap sounding names are crap, u might as well have no muffler at all...
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-33961
sir_GTR,
look at the link below, you should also try JMS is adelaide as they
would have some good second hand GTR Exhuasts. or if you email me i can put you in contact with someone in Melb who may be able to do you a HKS Hiper cat back for $950 or so. But $2300 is quite good incl cat as you can see the site below would cost you $1995 for N1 front pipes and cat back. Don't get JunBL
hype,
this place sells N1's and other Apexi gear but do nt have a show room
http://www.belperformance.com.au/price/data.htm
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-34142
Another thing about exhausts
Is there really much of a difference with the name brands? I want to get an Apexi N1 muffler, or perhaps a nice big HKS one, or something that looks nice and sounds good. Then ill get a hi-flow cat.. But for the rest of the pipes, does it really matter what brand it is? I was thinking just getting one made from one of the local shops which do good jobs..... its heaps cheaper, but is there any real difference than if it were a Apexi or JunBL etc..
they're only pipes - so does it really matter what brand it is?! Cats/Mufflers i can understand, because theres different noise/flow issues, but as for the pipes......
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-34485
i would suppose that the brand name jap pipes are well engineered designs for better gas flow at the bends? just taking a guess... in that sense, the premium you pay is a guarantee of quality... whether or not ur local shop can match that depends on their knowledge and skill... if they can and it saves you a few hundred dollars, heck why not :)
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-34599
i'm running a megaphone back box on my gts25t... outside the car, it's audible that the car's got a zorst... inside the car it's faintly noticeable... no drone, at all! and all i've got is a 3" and hi flow cat, no resonators... if ur worried about noise but want the n1 for it's lower price, the silencer tip (~$100) may do the trick... somehow these straight sixes are much quieter :)
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-38947
I had an exhaust fitted from a Custom shop here in SA.
www.dtperformance.com.au
Basically its from the turbo back with a high flow 7ltr cat, large resonator then a large rear muffler at the back with a 3" tip.
All is apparently Marine Grade 3?!? S/Steel.
It isn't loud, doesn't drone and jumped boost up to almost 12psi from around 8psi with the std. exhaust.
You can have a larger tip fitted if you want but I like to keep attention away especially through those defect stations and bretho's that we have here so often.
It also allowed me to dial in some more timing before she would start pinging. With the std. exhaust it was really touchy.
https://www.sau.com.au/forums/topic/1721-n1-vs-junbl-xhaust/#findComment-38974
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
