I've done this on my car. Don't bother. The R33 GTR bonnet is longer and higher. It needs to be changed. Even the headlights, which look identical, are different. The GTR headlights have spacers to push them out further forward. Here is a list of items which need to be changed. Don't let anyone tell you that you don't need to change headlights or that you dont need the front guards raisers. Everything needs to be changed. It ends up a VERY expensive exercise. Trust me I know...
GTR Bonnet.
GTR Bonnet Hinges.
GTR Bonnet Latch.
GTR Guards.
GTR Guard Raisers (Piece of metal which sits above front aprons to raise the guards.
GTR Headlights.
GTR Front Bar.
I think the R33 is the worst model to do the GTR front on as you need headlights and the raisers in addition to all the other crap. From memory on the R32 and R34 you don't need the guard raisers or headlights.
Here are some pics off my phone...
The front has been resprayed black (looks mint). But the rest of the body could use a spray. I can't really be bothered with the car anymore. Will probably be up for sale soon. It's a Manual Turbo. Probably looking at around 12.5k if anyone is interested.
what bonnet is that? looks hot?
So your selling lol wouldnt wanna sell me the gaurds, headlights and bonnet then? haha
Hey bruv, if u need parts ive got my whole front end which i wanna sell :)
Topstage F/Bar
Topstage vented front fenders +20mm
Topstage vent blended into original bonnet
Topstage side skirts
Wanna convert back to stock to sell the car.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
