yeah ive searched, im well aware of the various problems of missfirings and their solutions. however read on. I just got my 25 package running in my 32, still running stock turbo and ecu, all it has is cooler, exhaust and a boost controller atm. Boost is set at 0.7 bar max. Now the car drives fine down low, and pulls quite clean and smooth until about 5000 rpm at WOT. above this it hesitates like a misfire would some times it even starts to clean up before getting worse around 6500ish.
the motor has new plugs, have inspected coil packs and all of them have their spings (no carbon ectrodes like RB20 plugs tho?) all are clean and not cracked in anyway.
not sure what else it could be?? any ideas?
Cheers
Simon
https://www.sau.com.au/forums/topic/172108-rb25det-missfire-woes/
Visual inspection of coils MAY NOT show any obvious problems, other than soot/carbon/grime buildup that would lead to tracking. Try wrapping them with insulation tape.
Otherwise you could be experiencing the rich + retard syndrome. My R33 did, with nothing more than a 3 inch exhaust + pod + FMIC. No boost changes. Stock ECU said the mass-flow was too much and did something about it. Symptoms were much the same - ran fine down low, hesitating btwn 4600-5400 and then picked its act up and went much harder to redline.
Sounds like you have the correct heat range and gap for the spark plugs. Doesn't matter much whether they're copper, platinum or iridium. That just impacts cost and plug service life.
You could try to swap in a different stock ECU to compare, if any mates have similar vehicle.
thanks for that mate, i'll pull the coils back out and try wrapping them. Its sure annoying!
hey man im in the same boat.. only when its cold tho and i see boost over 14psi..
iv got full 3.7inch exh from turbo with 5inch tip, apexi power flow, 6x3x80 fmic and factory boost solenoid(hi/low) 8/12ish.. on COLD nights hi boost creeps up to about 14-15psi and thats the only time i get misfire.. and sometimes if the engines cold and if i give it some stick.
i figure its my coils.. im sure its your coils as well.. to be honest.. save up for some splitfires aye.. get em for like 500.. till then nanny it or dont take it past 5-6k :)
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
