I've done a search but not found much related to my problem(s)
yesterday afternoon i noticed my steering went very heavy, tho in the morning it was fine.
this morning when i go to turn car on my front torque goes up and off the scale.
i'm unsure of that system i should be looking at to fix this problem.
please help :)
Edited by Angus Smart
https://www.sau.com.au/forums/topic/172137-32-gtr-problems-please-helppppp/
just tried to drive. fuel, oil pressure, rpm, and the torque one that goes to above and beyond do not work.
i've tried to get into the hicas fault check but it does not work..
car has the tomei lock off kit.
also windows wont go down.. soon i'll have enough here to write a novel!
its always heavy, doesnt change no matter how slow or fast, tho obviously it gets easier when your moving. but its still has the same force to turn.
this is the only problem i have now all others are fixed. but i'm still stuck :)
Have you tried to do the hicas diagnostics since replacing the dead fuse?
If you can't get into the diagnostics, you will have to start probing with a multimeter. Solenoid drive signal to steering rack, solenoid ohms, speed signal to hicas module, power to hicas module. Pick all the ones you can get with a meter, following the manual, and if you run out.. then try replacing the hicas module with one you know to work from a mates car.
james.
ps. you haven't got a thing on the wiring issues I'm having to sort out with this one.. rb20det AT, converted to rb26dett MT with wires deleted, twitched, taped, aaargh. good luck though.
Edited by heller44
Haha i figure i'll need a hoist for that right? to check all them voltages. i might find someone i know with the diagnostic tool also. which would help locate the problem(s) right??
and i did try get into diagnostic turn wheel press brake pedal etc etc. but i just look like an idiot it doesnt seem to work.
well i feel a bit better knowing my problem isnt that bad!
power steering fluid, 4wd fluid in boot, (could be air bubbles in lines or just not enough) issues with wiring, issues with hicas computer on parcel shelf, issues with speedo/speedo cable. if worse comes to worse, id find a good qualified mechanic that knows GTR's. maybe even PM sydney kid
Angus Smart.
take your car to your closest or friendliest Nissan dealer and ask if they can fit up the "consult" to it and find out what is wrong. Hornsby Nissan is one Nissan dealer that should have the card for R32 GTR as they sold them new years ago. If you ask nicely they might find the problem for you for free and then you can head in the right direction as to what to change, replace or fix. Consult will check all the system outputs and inputs for you saving days of chasing your ass, and wires.
hope this helps.
Good luck.
how's our other thing going???
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
