Well my rebuild is on the way.
if anyone remember's i blew my little two litre engine at the phillip island sprints not too long ago
turned out that my head gasket blew and filled the cylinder with water then BANG!!!
too much boost... car was pulling 238.8rwkw with low compression.
so ive finnaly got my mechanic to start the rebuild... ha ha with a few extra goodies...
i chose to re build the 20 because there is too much legal issues with change overs to the 25 or the 30
im happy with the power i had any how..
here's my mods
3 inch turbo back exhause with hi flow cat
gt30 450hp turbo
fmic
greddy boost controller
660cc denso injectors
high mount exhaust manifold
wolf 3d version 5 computer
k and n pod filter
new stuff im getting are as follows:
rebuliding with forged pistons
shot pinned conrods
plenum
cam
hi flowing the head
clutch
oil catch can
just wanted to know everyones opinions
is there anything else i should do while shes open???
what power do you reckon ill make???
https://www.sau.com.au/forums/topic/172145-my-car-will-be-back-soon/
Who told you that mate?
There would be less legal issues (as paul has alluded too) because sticking with a high mount is like painting a dogs balls bright orange :sorcerer:
Good luck with it either way :)
If you want advice on legalities or your concerns, shoot me a PM :P
I tend to agree with Ash and Paul.
Not too hard to fit an rb25 or rb26 with std ecu, get an engineer's certificate and epa approval, then fit the usual mods.
As previously stated; a high mount is probably the worst option, with regards to legality.
sorry boyz but i checked it all out to make the gts-t comply with the engineersyou need to change heaps of shit may as well go buy the gtr.
high mount i agree is a magnent buthow easy is it to change?
we all went through this before i started
if you guys read the post i wanna know what power you think she will make and if i should do anything else while shes open???
no mumbo jumbo crap about legal shit its been discussed in like 75% of all posts.
What cams and what does high flowing the head mean? Cleaned up ports, match porting, modified combustion chambers???
Depends on what pistons you are running, and whether you are usign good rod bolts etc, but i would say the engine on paper should be strong for 19psi and 250rwkws all day at 7,800rpm :D
yeah i reckon so too but my guess is ill put out around the 280rwkw mark on full boost maybe 22 23 psi only because my last engine was screwed with low compression thats why it wasnt makin power in the first place.
we'll see anyway but id be happy with 260kw all day long at 18 19 psi
the plenum will shorten the intercooler piping hi flowing/porting the head will allow more air flow in. im using the best parts in my engine ive left it to my mechanic on what to get but he said it will put out good power and be real strong. hes also deciding on the cam to bring spool up a little lower
depends if the plenum is shit or not.. u dont want a 25 cause of cop trouble but you highmount your turbs? i guarantee you the popo wouldnt be able to tell the difference between my 25 and a 20.. unless pettit busted my nuts.
i didnt want a 25 not because of cop trouble but because it would have cost soo much to get the engineers for it and i dont have all the stock parts of a 25 to change it back once its modded and i would have put my high mount/same turbo ect ect on the 25 anyway
thing is if i got epaed on the 25 with no engineers id be screwed completely
the way i have it now is i have all stock 20 parts if i get done i change it back cost is a little less.
to get an engineers on a 25 you need to do breaks gear box ect basically need to make the 32 up with all 33 parts.. well thats what the engineer told me to get it to pass
too much stuffin around rebuild for the 20 was cheaper anyway and i have more money to spend on performance parts.
cant wait to get my baby back on the road.
its gonna be a pretty tuff20 actually is that #plate taken?? sounds good
anyway it will turn heads i bet i pull 260 270 rwkw easy
we will see ill take bets if you's want $$$ put money down winner takes all
my bet is 260 @ 18psi
280 @ 22psi
Just a stab
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
