  • Replies 43
like wise, seems like an oilcontrol issue there.
but yeah, we're not saying thrash the shit out of a fresh engine, just dont baby it whatever you do, besure to use most of the rev range and keep the boost to factory levels and load it up up hills often. this is how i have run in several engines in the past (rotors and piston engines) and ive never had a single issue with them.
someone posted the link, but seriously click it and read all about it.
HERE
HAHA bed the rings in (use str8 mineral oil) for a few hundred km's.... then bag the shit out of it. We drove cats car (9k SR20 build) to mt buller... dropped the oil then road tuned it fully (1.5bar) on the way back the next day, never missed a beat.
Not exactly relevant but:
Ever seen them break in a comp engine at the moto gp or F1? few small revs then 5mins of 2000-redline-2000-redline-2000-redline-and so and so on... crazy shit. Sounds nuts, i was nearly deafened
Edited by URAS
this guy has a good reputation in the european car industry. hes one of the few builders in syd.
well it just took a nose dive..... run in wasnt the cause.
From what I know and what I've seen on my engines and others:
Complete building engine
Install engine and ancillaries
Dyno tune run in. Ie. Run for about 20 mins varying the rev ranges and acceleration and deceleration levels. We were revving my car out to about 5500rpm
After the dyno run in, load in required engine tune
Put the foot to the floor and start pulling max power runs! FYI, with one of my engines before AutoSalon, we were pulling 450rwkw runs within the first 3 power runs and eventually settled at 632rwkw after about 9 runs and pulled it back slightly. After AutoSalon, we wound the car back to 380awkw and the engine was fine.
Good builds and good tunes, care when warming up and some sympathy lead to longevity of the engine. Once the engine is warm, it should be able to handle whatever you dish out at it within reason.
this will be discussed at length with my mechanic and i will pm him this thread. thanks to all for your imput. thanks to the topic starter as a lot of questions doubts worries etc have been answered.
Cheers, Ron
Just a quick question, as i will soon be in the same situation:
How do you warm the engine? Sounds silly, but i want to clear it up. Do you just start the engine and let it idle till it reaches 60deg or so. Or start engine, start driving straight away, but taking it VERY easy till it reaches temp, then drive it hard(ish), within reason.
Once my car is back i plan to load it up with about 100kg in each passenger footwell (300kg), then take the back streets to Kinglake and surrounding areas, do an oil and filter change once i get home, then do it all again the next day.
It will be too hard to convince my mechanic to bed the engine in on the dyno then do a full power run and tune 20mins later. His build, his rules, his time and money should something go wrong :thumbsup:
my rb26dett got rebuilt about 15,000km ago and I just went up the hills in 5th changing it up with load, worked good. dropped the oil at 200km, then regular changes
Personally, I after I start the car, I let it sit there for about 1 or 2 mins and then take it onto the street so that the fluids can circulate. Since I live in Richmond though, I've got traffic most of the day anyway so the car just sits and idles in peak hour traffic. I have always found that the temps come up a lot quicker if the car is moving. When I first hit the roads, I change gears at under 3000rpm and once the water temp gets to the middle of the gauge and I see the oil temp gauge get to to about 65 degrees, I think it's ready for some punishment. Usually, that's within about 10 mins of city driving depending on external conditions.
I did do an engine oil change after about 100kms of "running in" but didn't change the oil filter until the 1st service.
actually.. come to think about it, the bearings on the m3's are REALLY thin. the crank wasnt re-ground and new bearings were put in.
im sure that would need for the bearings to bed in to some extent. i guess on a fresh rebuild with the crank reground it would have less of an effect.
im just regurgitating information i was fed.
Nearly had it there security.
If you have the appropriate clearances for bearings, piston to bore and ring end gaps, you dont need to bed the engine in, you can just go and thrash it without any issues. However if you run tight clearances for bearings, piston to bore and rings then you have to do the whole run in process for fricken 1000-1500 kms. Before anymore misconception goes on, people should have an understanding of how it all works. If you take a rebuilt motor with tight clearances, and try and thrash it, it will shit itself! 9 times out of 10 it will be a spun bearing.
Tight specs means run in required, loose specs mean you can thrash it straight away. Road cars for instance are almost always rebuilt with tight clearances, while race engines or high horsepower engines will be built with looser clearances as they are expected to be thrashed and not run in as most race cars cant be driven on public roads.
URAS, f1 engines are built for a short lifespan. There clearances would be spot on for instant full noise racing. Once a motor is built, their run in is as you say it, and after that its probably tune check and then go for gold. Once that race or two are over its a new motor again.
Edited by r33_racer
yeah thats why i said not exactly relevant.... i build a lot of engines and if you do it right they dont need much bedding in (1500 is way overkill), machine tolerances are 100 times better than what they were.... gone are the days where you have to wipe bearings to get em exact. Shit i get each bore finished to suit each piston and filter through a pile of bearings (maybe up to 4 boxes) to find as close to perfect as i can get.
Edited by URAS
al, the worst possible way to warm up a car is to let it sit and idle till it's up to temp. especialyl bad if it's a fresh engine. for any engine the best process is:
start car.
wait 20secs or so ensure oil pressure is up and everything is cool.
start driving.
take it fairly gently until oil temp is over 70 and water temp is over 70.
then you can give it some stick.
so in short the best way to get a car up to temp is by driving it. don't forget your gearbox also need to come up to temp and tha'ts not happening whilst car is idling in garage, same goes for diff (and transfer case if you have one) and brakes etc.
I was thinking along these lines. What piston to bore clearances did you use on your GTR Leewah?
For my 2c I told my engine builder my planned run in process (which I had got from someone else and involved about 5000 k's) and he told me load it up where possible, vary the revs as much as possible, increase the revs gradually over the k's and I should be redlining it occasionally by the time I got to about 500k's. He said if it's going to blow up he wants it to happen within 500 k's.
I certainly noticed the tightness as first and it didn't fully free up until about 1000 k's. I have tight clearances though. 2.5 thou piston to bore.
I honestly don't know. The engine was already built by the time I got to the factory and it was in the car. I'm not one for the really technical stuff. I just posted what I saw but my engine still seems to be going strong after 6 months :)
start car.
start driving.
^^^^ This is correct, I don't know of a car manufacturer that doesn't recommend this method now. They all say the best warm up is normal driving.
sorry guys havent been on sice i started the post.
i would be interested in arep3's mechanics advice and how you go with your "run in"
i havent really askd my mechanic the best way yet but im pretty sure he said take it easy for the first 1000
i will ask him in detail...
let me know how you go my car is about a month and a bit away still he just started ordering parts.
do you guys really think its necessary to change the oil at like 200km?
i guess it would be good cause you get rid of all the shavings but i thought it would be only done at 1000 - 1500 mark and that was it??
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
