My R32GTR runs with coilovers (around 355mm front guard height).
I have adjustable front upper arms, and have around 1 deg neg set up.
This means that the upper arms are quite extended (to reduce the neg camber when it is lowered).
The problem is that the outers of the arms are fouling the inner guard, and actually have bent the lip of the inner guards a bit...
How does one fix this problem, without running a lot of front camber?
The pics should make it clearer...
May sound stupid, but are the in the right way?
I had this problem when I got my upper arms, turns out I put them in upside down, gave me lots of castor and not much camber. :)
Flipped the arms around and can easily run 1deg camber at 350mm ride height with no issues of fouling.
Edited by salad
interesting... can you do me a favour and see if the fat part (i.e. the female side) is on the outside like we have on mine, or the skinny part (ie. the male side) is on the the outside of yours?
cheers Showza!
Ah bugger, mine are different to yours though, mine are a turnbuckle style arm. But would only fit in one way anyway, one end is slightly wider than the other.
Only thing I can think of is are the arms staggered the right way? As they look like ---> I they should be staggered so the upright is pulled foward as far as possible. The body end looks right, but cant really tell for the upright end. But seems a bit odd that the arms themselves would be around the wrong way...
Edited by salad
Now you've got me worried.
I fitted adjustable bushes to my upper arms yesterday and I'm waiting to have a wheel alignment on tuesday to set my camber at neg 1 deg with 345mm ride height.
The arm looked like it might go close but I thought it would be ok because I had never heard anyone say they had a problem... until now.
Come to think of it I thought the suspension felt rock hard when I tried to bounce it.
I thought it was the new bushes being really tight but now I'm thinking I may have your problem.
Are you sure you have NEGATIVE camber. I would have expected the adjustment to be compressed to give negative, ie shortening the arms will pull the upright, and thus the top of the wheel, in towards the centre of the car.
This may sound stupid - but the stock ones are handed.
Did you put the right one on the right hand side & the left one on the left hand side?
Also what is your ride height & how much castor are you running?
Yep i checked the fitting guide and there is only one way they can fit with the adjusters on the top.
Ride height is 355ish and the castor rods are standard.
something about those arms looks odd, do they have any offset like the std arms? almost like the upper arm is swinging in the wrong area under guard...
They are offset like the standard arms, you can see that the top pic is the RHS and the second pic is the LHS. In the LHS pic you can see the offset bit in the top right of the pic
The shock mount simply holds the shock absorber - it has absolutely no bearing on camber.
Ronin - did that 1 deg neg come from a wheel alignment machine?
Yep it was done on an alignment machine. It may have slipped though if they weren't done up tight enough - It's getting towed to the workshop tomorrow so hopefully can sort it out.
Many thanks everyone for the replies, keep them coming!
I have the same adjustable arms - if mine were extended as far as yours are they would foul the guard as well. I have 1 deg neg camber but the arm is only about half way extended, and i have about 10mm clearance. IIRC my car is around 345mm hight, which should mean i need to extend the arm more, not less, so NFI whats going on with your setup... If you're in Sydney and want to check out my install, let me know.
Mine did that when I asked them to wheel align my car at -.5 deg camber. It made a knocking sound every time I hit a bump. Had to knock bit of metal straight and prime, paint exposed metal.
I triple checked that I installed them correctly.
I think They don't like anything less than -1.2deg or so depending on alignment of vehicle.
the arms are definately installed properly, and it looks like it's the upright hitting the gaurd not the arms. the only way out here is run more neg. so hardnen up boyo and run more neg.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
