do your self a favour brother invest in a genuine HKS SS blow off valve with adaptor its not extream flutter or cost (external waste gate = flutter sound) but its sounds almost as good in its primary dump stage (lower boost levels through gears) dont be a boggie MF with your pride n joy it will thank you in the long run GL.
Edited by SXY-33R
hmm its really that simple huh
It sure is. It's about a 10min job(drink the coke, take off bov, trace shape then cut). I did it a while ago, but then the car started to backfire and I got sick of it.
If you like the sound, do it. It doesn't matter what others think. If you like it, do it. You're the one driving it, not them.
Cheers,
Adam
Yeah its as simple as the coke can thing.
I got bored one day and did it. Bout 5 minutes work.
Got sick of the fully sic re VL turbo sound, not to mention the backfiring and the constant stalling. This would also lead to it running rich as f**k and burning way more fuel.
Ps. Don't do it
Hey,
Yeah, wouldnt blocking the bottom of it or whatever your saying stop it from releasing the pressure like it was designed to do and cause the turbo to backspin or something and therefore damage it???
IMO you should just do what SXY-33R said and buy at HKS atmo venting BOV...
bud, i wouldnt dream of doing it to my r34... just to many risks for a bit of fun...
lol well i cant talk because i too wanted to do it before i saw and heard a few dramas people were having when they thought how cool they were heheheeee
point is
now,
flutter = cool
later,
flutter = turbo bang!
cheers
flutter = 25 psi for 1 .a bit years then 20 psi for 1 year = still good, no shaft play. on vl turbo with highflow
usually u put the afm in the cooler pipes and put a metal intake on the front of the turbo for ultimate loudness. and put a pod on or not is up to u. il be doing it tomorrow on my 33 but leaving the afm normal position. u can hear the plastic and doesnt sound as good but my atmo blow off valve still goes off so its like half tutututu half blow off noise. it may go high pitch flutter even through the plastic pipes with the bov hole shut up
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
