Paul where can I get a HKS GT-RS for $2500. I would apprecciate your help.
Paul will I get water and oil lines for $2500? Or will I have to pay for them, as well?
for $2500 you can get a hks gt-rs kit and then sell your old turbo for $500 (if it works) so $2000 changeover
it should come as a complete kit too.
$1000 for oil and water lines?
Ease up on the bullshit mate.
What are u on about mate. Ring em yourself and hear their rubbish first hand... thats what they told me... how can u even comment :D
The last post
I call these other company to find out what the turbo would cost.
I wanted to purchase a HKS GT-RS turbo was told it will cost $3600 at best.
So I call someone else and was told to call another guy and his price was $2500 for for a Garrett GT-2871R.
And I would have to buy all the lines and gaskets too.
So the truth is this the HKS GT-RS will cost $3600 and the Garrett will cost $2500.
Thats for you help.
If you have a budget of $2500 and a minimum goal of 250rwkws with fast spooling, get the HKS GT-RS that you already mentioned.
Definately reach your 250rwkws and up to around the 280 i believe plus the kit on nengun delivered is $2276 with EVERYthing needed for a bolt on job.
http://www.nengun.com/hks/turbo-kit-gt-rs
Brand new turbo
All lines included
FAST spoolin'
Get it !
The last post
Thats for you help.
No worries mate... If people could be bothered to search and find out the facts before saying someone is talkin bullshit im sure they'd be as suprised as i was, sure the turbo costs $1700, but to be able to put it on your car "yourself" its $2600. What if u were payin for someone to install it...! more!
I agree selling the old turbo will help but finding someone to buy it would be the problem...
I bothered to do a search. Because you are from SAU you get it for $1692 just for the turbo.
If you get the kit it costs you $2340. That's a $648 difference. A far shot from $1000. Also I'm told the kit comes with:
-20mm Spacer Kit which comes with studs and 2 gaskets to suit.
-Gasket Kit including genuine Nissan dump pipe gasket.
-Oil and Water line fitting kit.
-Silicon reducer elbow 2.5" - 2.0" for the intercooler plumbing.
That's a bit more than just oil and water lines. Now maybe that's still expensive. I don't know. What I do know is that you told us almost $1000 for oil and water lines.
Look i dont really care if u wanna argue your point, but the fact is its still near enough to $1000 dollars more for a few gaskets and 2 hoses, you could buy gasket glue for the flanges if u wanted? I bloke from work did this on his 180 and its still fine. It just pisses me of that they advertise it as $1700 but in reallity if u intend to put the turbo on your car as im sure most of us do when purchasing a turbo it'll cost a fair bit more.
yes you could use gasket glue but that the shit house cheap way of doing it - and not properly.
Race tape works wonders for holding on a front bar but Nissan don't use it from factory. Because it's shit.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 馃槢   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When鈥檚 the tow ball on the 33 coming? 馃檭
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
