moobaque Posted June 10, 2007 Share Posted June 10, 2007 Hi All, Firstly appologies if this gets posted twice but either my nets up the shit or something funky is goin on with the sau site. Anyhoo, a few days ago I installed Endless CC-x pads all round along with a brake fluid bleed replaced with Motul RBF600. obviously im still in my bed in period but the intense squeeling coming from the rears is discusting. Under heavy braking they are relatively silent (which is good as they are bought for track day reasons). But with the less intense preasure used on the street the squeel is huge.. and appears to be getting worse. Whats happened on my drive home tonight is that the brakes squeel from the touch of the pedal till stop, but now when im at about 15kmph or less a much deeper vibrating, almost grinding sound seems to start to sneak in. is this just what happens at bed in with these pads or is something a bit funky going on? I would love to get this sorted asap as its almost making the car undrivable, and a threat to my life from angry people near me. (oh and i have done a search but returned nothing that came near my issue) Cheers Camden Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/ Share on other sites More sharing options...
Russman Posted June 11, 2007 Share Posted June 11, 2007 Hey mate. FYI my ccx rears don't squeel much anymore but they are a pretty aggressive pad and will squeel a bit. My front do all the time. ccx's might be a bit track oriented if you wanted street (quiet) pads. There shouldn't be any grinding when bedding in though.. I'd be checking installation. Did you do it yourself? Check the clips and rods that hold the pads in place. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3171527 Share on other sites More sharing options...
HKS-R33 Posted June 11, 2007 Share Posted June 11, 2007 ive got the same pads and after a while of light braking mine start to squeel really bad and i sometimes get the humming type of sound that you are describing. This only happens to my front brakes though. Ive been told that slotted rotors should fix the problem as it gets rid of all the brake dust. I would also like to know a fix to this if anyone has one. BTW my pads are definately installed correctly. Mike. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3171820 Share on other sites More sharing options...
Russman Posted June 11, 2007 Share Posted June 11, 2007 My fronts are slotted and rears are drilled so maybe thats why mine aren't so bad Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3171997 Share on other sites More sharing options...
moobaque Posted June 11, 2007 Author Share Posted June 11, 2007 Hey mate. FYI my ccx rears don't squeel much anymore but they are a pretty aggressive pad and will squeel a bit. My front do all the time. ccx's might be a bit track oriented if you wanted street (quiet) pads. I did buy them for track purposes but if im able to leave them in the car between meets it would be an advantage.. My fronts dont squeal at all even under light braking.. just the rears.. There shouldn't be any grinding when bedding in though.. I'd be checking installation. Did you do it yourself? Check the clips and rods that hold the pads in place. I did do the install myself, but im pretty confident its all AOK.. I'll check em out this arvo to make sure. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3172017 Share on other sites More sharing options...
Trust33 Posted June 11, 2007 Share Posted June 11, 2007 how much $$$ are the endless cc-x pads to buy. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3172175 Share on other sites More sharing options...
moobaque Posted June 11, 2007 Author Share Posted June 11, 2007 Checked the rear pad fitment and everything is fine... so doesnt appear anything in the installation is causing the noise how much $$$ are the endless cc-x pads to buy. i cant find my receipt but i think all 4 corners cost me $500.. possibly $600. Depending on what calipers you have you will be able to get them cheaper off the net. I think nengun sell em for about $411, but you'll have to wait a while for them to arrive. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3172359 Share on other sites More sharing options...
MrStabby Posted June 11, 2007 Share Posted June 11, 2007 Did you use anti-squeal shims with either grease or that brake silencing goo? If not, then the installation is probably the problem. The Nissan shim kit comes with some grease to use with the shims, but i just used the red CBC brake squeal goo (should be able to get it any spare parts shop) to 'glue' the caliper pistons to one of the shims, and the rear of the pad to the other shim. There was a little grease left between the shims. No squealing at all Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3172563 Share on other sites More sharing options...
moobaque Posted June 12, 2007 Author Share Posted June 12, 2007 Did you use anti-squeal shims with either grease or that brake silencing goo? If not, then the installation is probably the problem. The Nissan shim kit comes with some grease to use with the shims, but i just used the red CBC brake squeal goo (should be able to get it any spare parts shop) to 'glue' the caliper pistons to one of the shims, and the rear of the pad to the other shim. There was a little grease left between the shims. No squealing at all I certainly have shims in place but i will investigate some brake grease/glue, thanks. Link to comment https://www.sau.com.au/forums/topic/172207-endless-cc-x-break-in/#findComment-3174300 Share on other sites More sharing options...
