Can I Fit This In The Boot Of An R33?
HIDCBL
 Share
For those that don't know, its 1040mm from the RCA tip to the Power tip at the other end...
So... can it fit running side to side in the boot?
With still enough room for a sub box?
what the hell are you looking to power? I have over 3kw RMS (monoblock) at my disposal and im struggling to fit that in... 2 12's and a few amps... and space is minimal...
If your running that, and only one sub, then yeah, you can probably make it fit... ill take dimensions tomorrow... but if not...
im gunna say that whatever your aiming for with a name like that, then no, the boots are tiny... Dont burden yourself with lack of airspace...
get a stagea! same engine. but its a lot roomier! :)
that, or rip the back seats out and re-register it as a 2 seater...
I was thinking that....
Doesn't matter now anyways, guy pulled out of the sale, so now i'm left with my E-audio 3000D (we were gonna swap)
What sort of space you reckon you can get out of the R33 boot? cuft?
there is actually a part of the chassis between the boot and the rear seats where the battery, HICAS system and some other shit sit... there is only a small gap once you take the seats out... not even enough to pass a soccer ball through...
you would have to design 2 separate enclosures... not the best car for DBs man... still a fine car, but if your serious about DB Drags, this is not the car for you...
i bought it cause its a fantastic car :worship: plus i needed the extra horse power to cart the system around :)
its quite a challenge building something decent out of it...
I have no idea on a 33 but 34 has a metal aluminum plate which is removable (now removed) it holds in the rear seat (centre of it) I needed it removed for better sound..
 Share
