Guest a31rb25
just for shits and giggles if you were wanting to upgrade your brakes but keep the 4 stud standard set up, whats the best way to go about it?
the best way to go about it would be to work some more hours, quit being a tight arse and get a 5 stud set up.....
Just Jap 5 stud hubs $550
RDA Slotted R33 discs = cheap
Bendix Ultimate pads = cheap
R33 Calipers = cheap
i don't know the RRP prices for the stuff with a 'cheap' price tag as i got all four corners for approx $600 for all rotors, calipers & pads, but that was mate's rates
https://www.sau.com.au/forums/topic/172238-brake-upgrade/#findComment-3187888
There's no need to upgrade to 5 stud unless you have difficulty finding the wheels you want in 4 stud.
The R32/S14 calipers bolt straight on, you have 3 options for discs.
1 - redrill the disc (9 holes) so it's 4/5 stud multifit
2 - buy blank faced R32 rotors from RDA, and have them drilled in 4 stud
3 - buy R33 non turbo rotors (same size but factory 4 stud)
If you upgrade to R33 calipers, buy blank faced R33 rotors and have them drilled in 4 stud.
https://www.sau.com.au/forums/topic/172238-brake-upgrade/#findComment-3189363
i would NOT buy these just jap hubs! they are pretty shitty quality and made of a "soft" alloy!
do it properly using nissan gear and you cant go wrong
https://www.sau.com.au/forums/topic/172238-brake-upgrade/#findComment-3189640
"the best way to go about it would be to work some more hours, quit being a tight arse and get a 5 stud set up.....
Just Jap 5 stud hubs $550"
ha i work enough hours as it is not being a tight arse, if i wanted 5 stud i would of said so, there was no need to bar up at a simple question. i have the wheels i want in 4 stud..
AND ive seen too many of the JJR 5 stud conversion hubs split in half due to complete dodginess of manufacture...
cheers for the help Daisu.
https://www.sau.com.au/forums/topic/172238-brake-upgrade/#findComment-3193163
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
