Hey Al, i never got to check out your front bar properly after the tint day... after cutting the bumper support, have you noticed any structural stiffness reduction - ie do the ends bend more easily or does the front bar seem less rigid?
You should be able to use the cut out bit as a source of plastic for a plastic welder to patch them up again. I've never seen one patched up, the couple I have seen with the front section removed just have some ugly square holes left over.
Also, where do you put your plate after you do this? I hate plates that are off to one side, reminds me of a bus or army vehicle or something. I'm thinking it would look ok if suspended from the top section of the front (low profile plate only). It would still interrupt air flow a bit, but not nearly as much as the whole crosspiece does.
this is my front bar ,I had to lose the front bumper blinkers cause of the intercooler,so i wired the parkers up as blinkers and moded the headlamps to run parkers and headlights.The bumper was already damaged when i bought it(underneath) so i wasnt really fussed with spending money to plastic weld the gaps.So i just cut it out bigger so it didnt have any:)
Originally posted by T0nyGTSt
Hey fairies...
See the pic below.
Personally I don't think I CBF doing it. Flows fine.
T.
Forgot to recheck this thread, sorry for the delay. Tonygtst why is MY pic (that i posted in another thread. months ago) of MY CAR labeled as 'ben_front"?????:D
Is side monted plates illegal, i have never been pulled up on it? I thought that if a bar does not have a dedicated spot (and mine now doesn't :)) that it is ok to mount on side as lonf as it is clearly visible.
Ronin 09: I personally have not seen/noticed a differance, as the support bars, that held the middle bar, are still there, on either side of the cut out.
I would think this mod is illegal, but may not be picked up as it looks factory. What mods are not legal now a days?
Ben has a maroon 33 as well and wants to do the sex conversions... his will look like yours soon LOL
I'm running around with an IC still behind the stock M-Spec bar.
Nah NSW cops are just being arseholes. Heaps of 'em gave me the "Alfa 156 is ok as it's stock, yours is not stock".
T.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
