  • Replies 46
lol @ aragosta being sweedish ohlins. this may come as shock news but so called 'sweedish' ohlins are called ohlins. some may find that hard to believe but trust me on this.
aragosta are ok shocks but they have nothing to do with ohlins.
yeah true dat, Aragosta claim to be made in the netherlands.... but yeah :) me think its a bit like the made in japan stickers on a lot of gear :)
Aragosta is good gear but not ohlins (yamaha) good....
Aragosta is not made by Ohlins.
The ones I have "examined" have been, can't say that ALL of them are though, because .........
Aragosta claim to be made in the Netherlands,
Those ones are made by AST, the ex Koni guys.
Unfortunately the Ohlins made in Japan (Yamaha) are also called "Ohlins". Hence why I differentiate by calling the Ohlins made in Sweden "Swedish Ohlins" and the ones made in Japan "Japanese Ohlins". So don't look for stickers that say "Swedish Ohlins" :D
Aragosta appears to be nothing more than a "marketing" name, they simply rebadge other people's stuff. And charge more of course. :D
:D cheers :D
sorry to say guys but i have heard that you now req (in most states) an engineers cert if you fit coil overs. i.e they are now illegal. heard this on R31 skylineclub.com http://forum.r31skylineclub.com/index.php/topic,79654.0.html read down a bit and you will see the post were i got my info from.
The truth is only standard windscreen wiper blades are "legal", as in the ones you buy from your local Nissan dealer. Non standard mud flaps are also "illegal".
But no one bothers enforcing it. The current "scare" on coil overs is exactly the same.
:D cheers :D
i have been to the factory and it aint in the netherlands :D but yes the above applies.... capn rebrand, use a well known base to build from and modify (in some case colour only :D )accordinly.
Bit like the URAS coil-overs.... they are poison dear 3k plus.... but each set is hand built and bench tested, they start from DG-5 cartridges, get new shafts, new valving, lightwieght swift springs (first spring choice of 80% of jap race teams) and a individual certificate of specs.... they will even build to order if you have the relevant specifications. 99.9% of the aussie market will never even consider a coil-over at this price..... even die hard guys stuggle to invest 1/3 of thier car in suspension..... :D
i dont no too much but a friend of mine had super streets in his 32 sedan and to date he considered them the best mod he did, great fun on the street changed/improved the car 10 fold without too much compremise on street comfortablility. dont know about track. but i agree with what you said previously. get the tienSS if they arent what your after in terms of track performance i doubt youll have trouble getting rid of them and atleast then youll have a better idea of exactly what you want from your suspension. just my 2c.
cheers Dario
ps. dont quote me though im an ae86 boy so my skyline knowledge isnt too crash hot lol.
cheers Dario
The new greddy type-s seem to be the flavour of 86 drivers in japan and the us after they won a test day done by Tarzan and Tsuchiya... tarzan even went on to write a review for dspeed i think.
yer the greddy damper S had a look into it already and had a few people post the review on them in the ae86dc forums, they seem to be the goods :whistling: about 2.2k landed in melb. i got a link to the review if you like. *thumbs up*
http://www.jdm-option.com/eng/parts/06_08/types.html
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
