ok guys im goin to build a stage 3 hks 2.8 stroke and im wanting 670-700 awhp its for street and track so i want to least amount of lag. it looks like a hks to4z will be my best option but if any1 has any ideas or other comments please do and if any 1 with this turbo can comment and give me ideas woud be great
As stated in the other thread you need a 900-1000hp huffer.
A T04Z is not one of these.
Plus for the circuit, i hope you have very deep pockets beause stopping and turning is going to cost you a fortune
ive got trust grex 6 piston up front and 4 piston down back and tein coilovers and hardware to match
if the TO4Z isnt big enough what will it max out at
Ive done a bit of research on the T04Z lately, as im currently tossing up between the T04Z and a pair of GT-RS.
700awhp is prob right at its limit, if not past it, couple of the guys on the forum have them and are running well into the 600whp range, but that is pushing limits.
I think HKS quotes them as a 700hp turbo. So i think you will need to go bigger, which means more lag = bad news for the track.
A set of high mount twins like Piggaz suggested could be a good bet.
700awhp is some serious power for a track/street set up.
Good luck with the build, HKS 2.8 is a good choice IMO. :P (if i can scrounge the funds it will be what i go for :thumbsup: )
I can be wrong, and im prob very wrong but ive heard someone telling me before that he has a HKS 2.8l with s T04Z doing 735whp?
Or could that be 735hp at the crank?
I would go for a high mount twin GTRS or 2835. If single, maybe a T88-33 or 34D?
jun 2.7l with 22psi making 605rwhp on pump fuel, its seriously running out of power after that i reckon considering it made 585rwhp on 18psi. i'd say mid 600s or so on race fuel is the limit and my setup uses big big cams and full head porting and supporting gear to push it.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
