I think it all really depends on what the purpose you have for the car is. If you are after basic/intermediate levels of tuning for street and the occasional track day, it's tough to go past the PowerFC as it's pretty much plug n play and can do nearly everything most people want.
If you want the best of the best and have the $$$ for it, you're definitely looking at either the Autronic or the Motec ECUs. Both have more parameters and controls than you could ever use but neither are plug n play and take plenty of time to install, tune and properly setup if you want all the goodies.
Have a look at the following threads for more info:
http://www.skylinesaustralia.com/forums/in...tronic+power+fc
http://www.skylinesaustralia.com/forums/in...r%20fc&st=0
http://www.skylinesaustralia.com/forums/in...p;#entry1024327
http://www.skylinesaustralia.com/forums/in...mp;#entry931292
http://www.skylinesaustralia.com/forums/in...mp;#entry716558
That should keep you going for a little while otherwise try using the search option in the top right of the menus.
you sound confused
i think you mean to wish to remove the factory airflow meters
600hp is fine with airflow meters
but if you insist motec and apexi powerfc will support no airflow meters
safc II will not support no airflow meters and wont go anywhere near 600HP
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
