Hi guys, I have a few parts for sale which were to be fitted to my 4 Door R32 but never quite made it on ;)
First up is a brand new Project Mu Braided Brake Line Kit for HCR32. These brake lines are a high quality heavy duty front and rear replacement for your factory rubber lines which are prone to perish, reducing your cars braking performance. The Project Mu Brake Lines feature stainless braid construction with a teflon coating to keep dirt and grit out of the stainless mesh.
These are very hard to find for R32 GTS-T and have been opened for examination only, but never fitted.
Asking price is $220.00
Secondly during my recent house move I found another new set of Clear Front Indicators for R32 GTS-T which have never been used and are still in their original box. I purchased these for someone else from Japan however the buyer pulled out at the last minute so they are up for grabs. These are difficult to find and look fantastic when fitted. I have had them on my own car for the last 6 months and they still look amazing.
First in, best dressed.
Asking price is $200.00 firm - No timewasters please.
Thirdly, I have a brand new genuine Greddy sandwich plate for Nissan RB20/RB25/RB26 available, with in-built thermostat and the facility to accomodate oil pressure and oil temp sender adapters. I purchased this by mistake and ended up with two of them, so this of of no use to me.
These is the real deal quality sandwich plate, no like some other cheap junk.
Asking $195.00 firm
All parts are located in Sydney on the Northern Beaches and postage is available at the buyers expense.
Cheers,
Nick :)
https://www.sau.com.au/forums/topic/172396-r32-gts-t-parts-for-sale-sydney/
Damn been looking for some clears... dont have the funds atm, need to save them for the weekend.
Ill keep my eye out and if they are still for sale in a fortnight or so I will buy :)
just another thing worth checking is that the sandwhich plate looks to have a thermostat built in which is good. so when engine cold oil goes into filter, then straight back to engine. when oil is hot it will pass through filter, then out to oil cooler and back. may need to check, but the big barrel shape in front of the inlet/outlets is a big hint that it has one.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
