nsta Posted June 12, 2007 Share Posted June 12, 2007 Hey guys, i got a very mildly modded r33 gtst, which i will be getting splitfires put in for,as the car misses no matter what, even gapping them down extremely, or taping the coild etc.... car is a 94 gts25t 3" full exhaust w split dump fmic boost tap running ~10-11psi pod filter w/cold air feed I want to know what gap setting to use with the splitfires on 10psi?, would around .8 be right?or could i even use 1mm without problems? thanks in reply. Link to comment https://www.sau.com.au/forums/topic/172422-car-running-10-11psi-and-splitfireswhat-gap/ Share on other sites More sharing options...
R31Nismoid Posted June 12, 2007 Share Posted June 12, 2007 1mm should be fine. If not, just go back to .9mm and it would almost certainly be spot on. Link to comment https://www.sau.com.au/forums/topic/172422-car-running-10-11psi-and-splitfireswhat-gap/#findComment-3174276 Share on other sites More sharing options...
nsta Posted June 12, 2007 Author Share Posted June 12, 2007 THANKS, ill try 1mm first, if not, then .9mm....will i notice any difference, apart from no more missing, going from .55mm gap to 1mm?? Link to comment https://www.sau.com.au/forums/topic/172422-car-running-10-11psi-and-splitfireswhat-gap/#findComment-3174292 Share on other sites More sharing options...
