Hmm so after some pondering ive decided to go for a S-AFC II, FMIC and fuel pump. And then in the near future hopefully a slide high flow.
From what ive read in old topics the SAFC can't really support bigger injectors, but would support a high flow yeah?
Still undecided on what pump to get, Walbro is deliciously cheap but people seem to have had issues with it. Was also going to get a Bosch 040 but aparently its crap and noisy :D
the SAFC isnt going to handle the high flow turbo very well. you'll be able to tune it slightly, but you'll be missing out on somewhere between 30 and 50rwkw from the lack of an ECU once you put a aftermarket / hiflow turbo in. Plus stock injectors cant cope with much more than ~225 rwkw.
The SAFC isnt a bad option, as it will hold its value, so when you put in an aftermarket ECU, can sell it for same price you buy it. Nothing wrong with the Bosch 040 if its installed properly. can just hear it over exhaust at idle, and you cant hear it at all once you start driving.
As i said in my previous post however, make sure you have set aside money for a clutch, especially if your still running stockers.. it aint gonna last long. might just be able to squeeze that into your 2k budget along with fmic, fuel pump and safc2.
Still undecided on what pump to get, Walbro is deliciously cheap but people seem to have had issues with it. Was also going to get a Bosch 040 but aparently its crap and noisy :)
You can always sell the safc should you want to change the ecu down the track, but it will be more than adequate for the standard hi-flow and won't loose you 30-50rwkW as stated earlier. In the dyno results thread people are running hi-flows with stock ecu and achieving 200-220rwkW, it's just a safer idea to get it tuned with the safc.
Find a genuine walbro pump with the higher L/min rating or a Denso pump from Kudos motorsport. 040's are a good pump put they're just physically to big for the r33 tank and if it's touching one side of the tank it will be noisy as hell.
When you say a walbro pump with the higher L/min rating, which one would that be? Only ones I see on ebay are the 255L/hour jobbies, the Walbro GSS 341. That the one your talking to or is there a model up from that? I WOULD like to go with the Walbro mainly because they seem easy to source and are one of the less expensive pumps around.
One is a GSS341 and the other is a GSS341HP, most dodgy traders sell people the GSS341 which is fine for standard cars, but for modified and larger capacity cars the GSS341HP(High Pressure) is required.
Sorry by l/min I mean't l/hr... brain lapse :) .
Edited by BAMR33
Hey not hijacking the thread but let me know how u go as i have similar mods to you and am in the same boat.. got full exhaust, boost controller and got same sorta money to play with. But i have splitfires and a h/d clutch as well:)
So the safc's are actually worth it? And i (and Lachlan33) would feel a noticeable difference with the addition of a tuned safc and a bigger fuel pump? I'm also debating whether to get a justjap or a hybrid cooler for mine.
Walbro's low pressure pump in this design is part number GSS315. GSS341 is the high pressure variant.
get swaybars and some coilovers, and maybe some castor rods if the budget can stretch that far ;)
Then you can corner faster and out run all the guys with stock suspension and 200rwkw :)
what he said, but forget castor rods :nyaanyaa: or enkei rims ;)
Whats the most important thing to you?
Is it "bling/rice'?
Is it better safety (the standard gtst needs some help with traction)?
Is it straight line accelleration?
Is it reliabillity?
Depending on how you answer these sorts of questions you will get some slightly different answers.
Remember that search is your friend.
If you are handy with a spanner the $2k goes alot further.
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
