im on the gold coast and have fought my way thru soooo many diy's, help guides etc on this site for a few probs with my liner but i am giving up, im not willing to pull apart my engine to find the problem because i dont have the time or the experiance with new turbo engines so im wondering can anybody recommend a good mechanic on the gold coast or further north towards brissy that specialises in import/turbo'd engines. (i drive an r33 rb25 det btw)
Thanks guys in advance, i need your help!
https://www.sau.com.au/forums/topic/172453-good-mechanics/
  R334door said:
whats wrong with your car? Noises?
yea, i found a few faq links with a few causes and remadies, basically i was driving home one day and went round a roundabout and tried to floor it cos i cut infront of a car and the car was rattling and jumping and wouldnt take off, it "hesitated" while making a strange noise and now wen i boot it it does the same thing, all the time, from the lights, dropping down a gear on the highway etc etc.
The faq said to cover the coil packs with tape but im not used to messing with anything more than the typical servicing stuff wen it comes to engines. unless some one has had this happen to them too id rather just take it to a mechanic and get him to look at it. 2 many things could be the prob, eg diff, oil systems, fuel systems, air flow, turbo etc. its scary. but yea im new to the area and dont no any mechs in the area hu would take on an import turbo.
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3174728
im trust worthy.. ive done many coilpack mods with silicone and have a tube here.. ill be happy to walk u thru it mate. i do everything nearly.. from coolers, turbos, exhaust to RB20 conversions in sils.. ive done quite a few jobs for members here and on bc.com .. and so far everyone has been happy :)
and best thing is i dnt bullshit you with excuses i can actually explain it and i actually knw what im doing...
'unlike taking ur car to say APC to have an apprentice drop a bolt into a wrx bellhousing hehe, think of the noise and damage that bolt did on start up..'
send me a PM if u have any queries.
also i do FMIC kit installs from $175 for S1 GTST, and $200 for Silvias... and so forth :(
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3177708
i called up gary and checked the website for elsewhere and i reackon i mite just try tokage, they seem to be the biz price wise, gunna call him again tomoz to find out when i can book my car in,ill keep u updated on how the search goes if i find others and will let people who havent been to tokage how i go.
Let the search continue
Dazza
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3189467
  MyR3408 said:
howmuch do they charge to get a set of coilpack and plugs replaced from a mechanic? rough estimate?
workshop rates are $90 and upwards my old place was $110 per hour!.. so ur looking at around an hour labour.. less but a shop will charge an hour just cause its not worth billing .5 hour.
coilpacks (splitfires) $560+ from slide..
plugs (NGK coppers) $4 each = $24 so ur looking around the 650 mark all up at a shop..
then they will give u a bullshit excuse that oh ur fuel pump is effed and ur harness has a bridge.. and tappet cover gaskets and ull walk out with a 1k bill..
i knw how they work i used to work for one.
pm me if u need some help or any other details..
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3190328
Ive got the coils and the plugs :D how much is it to install it/
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3190423
  made_guy said:
isn't there a tutorial to do them on here? i didn't think coilpacks and plugs were that hard to replace.
yeah there is but not on the Neo 6 ones. ive found the one replacing the coils on RB26
and instructions w/ pics on how to remove the top bit of the Neo 6..
but i dun have confidence to fiddle arnd with it.. not too confident :action-smiley-069:
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3190702
I just changed my coilpacks this afternoon. I'm not a mechanic which is why it took me 2 hrs but I saved myself $$$. My splitfires cost $465 delivered thanks to Perfectrun.
It really isn't hard to do at all, it's just that all the little fiddly connections and things take time if you don't want to break/damage anything.
https://www.sau.com.au/forums/topic/172453-good-mechanics/#findComment-3193006
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
    • Would be interesting what the price would be without the barracuda wheels. Looks like he dropped it down to 40k. Maybe his mate wasn't correct about the 50k evaluation. Has always been a dream of mine to own an auto 33. Looks like I'll have to keep saving my pocket money or ask mum for more pocket money.
    • Thinking about importing a stagea as a family car since i’m getting married this year, thoughts? Me and my fiance both like stageas, but don’t have any experience with them
