Hi m8,
Did you buy the plenum and get the throttle body spacer with it? or did you buy the plenum and the throttle body spacer?
I need a replacement spacer for the standard throttle bodies to fit a single TB plenum.
Do you want to sell that on its own? Do you have a part number for it.
Thanks in advance
If nothing else a free bump for you :nyaanyaa:
Kev
correct me if im wrong but thats not a spacer, its the back half of the plenum. you still need to use the stock throttle bodies with this plenum set up. thats why the inlet of the plenum is round so you can use a hose clamp on it, instead of square so you can bolt a single throttle body to it.
