just wonderting what oil everyone uses in their engines but now just every engine. the rebuild suckers with say 2000km's up on the clock(ie. after the run in period)
cheers!
also what should the oil pressure (say the guage) read/be in in gt-r's with rb26's at say 1000rpm, 3000rpm and 7500rpm(or red line) for these engines??? using a standard oil pump.
Edited by Turbz_13
https://www.sau.com.au/forums/topic/172493-blood-for-your-new-engine/
get the valvoline running in oil. use it for 2000k's then whack in some mineral oil and use mineral oil for 2 changes like gtx3 or something similar. after the engine has done around 15,000km's then go fully synthetic.
Do it this way and your engine will wear in better
good stuff guys!. i was just curious as to what everyone was using. i mean my engine has been run in and has almost done 5000km's. but i thought id check. im just letting the workshop that did the over haul use what everm oil they think but i thought it was a tad think for an rb26, specially a new one
Castrol Edge 10-60 from the very first turnover
Some castrol facts;
The name comes from Castor oil which is ok, they then turned their hand to esters.... and failed giving synthetics thier bad reputation early on in the piece.. they no longer use ester... it is left to oil professionals.
did you know that castrol/Penrite Sin fully synthetics are actually only partial synthetics? the only full synthetics in australia have to say 100% synthetic on the bottle.... stoopid loop hole in consumer law.
Also to achieve a wide spread of 10-60 (penrite too) you need to add alot of additives these additives are not lubricous therefore actually reduce and dilute the amount of lubricant in the oil....
Some castrol facts;
The name comes from Castor oil which is ok, they then turned their hand to esters.... and failed giving synthetics thier bad reputation early on in the piece.. they no longer use ester... it is left to oil professionals like redline, motul and a few other boutique oils.
did you know that castrol fully synthetics are actually only partial synthetics? the only full synthetics in australia have to say 100% synthetic on the bottle.... stoopid loop hole in consumer law.
Also to achieve a wide spread of 10-60 (penrite is worse) you need to add alot of additives these additives are not lubricous therefore actually reduce the amount of lubricant in the oil....
:D which are some of the many reasons I now only use motul chrono 300V, which is ester base, and full synthetic. plus being only a 10/40 does not need nearly so many friction modifiers. it's a great oil. :)
haha yeah i remmeber that bathurst where the sponsored Castrol car is pumping in tins of Motul 300V in the pits :P
Edited by Turbz_13
I just use what im told by my builder :D
I trust him to know whats good for the motor he made.
Good info though either way.
What spec grain size does he hone to run a synthetic oil from initial build are you using specillised rings? I prefer to use a mineral based oil for the first 100 -200k and then swap to a synthetic. If the rings havn't bedded in the first 100 -200 k then your in trouble - the will however continue to fully bed by around the 500k mark tho.
When you assemble the motor dont use oil in the bore. Use a crc like inox to lube the bore up for the first start of the motor. Bore cant glaze up and it helps bed the rings in extremely well.
We use motul also, 300v lemans.
Edited by r33_racer
Some castrol facts;
If you do some research into engine oil you'll find the lower number is a cold pouring index not a cold viscosity reference . Could you imagine a lubricating oil with a viscosity rating of 10 at 20 Deg C and 60 at 80+Deg C ? It doesn't work like that .
Good synthetic oils pour quite freely at temperatures significantly below zero C so pumping it round the system in cold areas is not the issue it once was .
If you look at good factory workshop manuals they tend to specify oil viscosity based on the temperature of the environment its used in . Obviously the colder it is the lower the viscosity oil is recommended which makes me think maintaining adequate oil pressure is oil temperature dependant .
I did talk to SK once about Castrol Edge 10/60 , he likes it and uses it with no probs I can remember . I'd like something a little lighter in the winter time and he said yes theres probably a small power gain to be had from a tad less oil drag . I don't thrash cars on the street so I probably don't need the oil to have the ability to get really hot to the point where pressure becomes an issue . If I did then a healthy oil cooler thermostatically controlled would cover most eventualities I think .
Cheers A .
Factory nissan recommends 7W30 i believe for rb engines....atm as my engine is older i am using Castrol Edge 10W60. havent had a problem yet. On a rebuilt engine i would be using a run in oil, and then a 7W30 or 5W50 or something and keep changing everyine few thousand.
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
