Blood For Your New Engine
If you do some research into engine oil
i deal with oil companies everyday. i know exactly what works and what doesnt..... and who promotes bullshit and who doesnt.
I used penrite-running in oil as I wasn't keen on cheapo bilo oil and since have run motul 8100 5w40. Its a 'true' grp 4 base stock synthetic.
Sure the castrol oils may work ok but if I pay good $$ for a full synthetic oil I expect a full synthetic oil.
Not to be ripped off with some grp 3 base stock that is claimed to be 'almost' as good as a grp 4 base stock synthetic.
Motul; you really cannot go wrong.
Spoolup; what run-in oil would you suggest? I did consider using the plain old castrol gtx that doesn't have non-friction modifiers..
The penrite running in oil I used is most likely recycled oil also but it was $28 for 5ltrs so not super cheap.
Mines still running well; travelled 60,000km's with forged pistons, king bimetal's and still compression tests the same as it did after run in.
Still doesn't use a drop of oil and oil pressure it good. :thumbsup:
5 DOLLAR CRAP for 500kays. and abit of boost abit of revs and no ideling or cruising
hi,
why do you say "no ideling or cruising"? i thought the opposite -- that i have to be tender with a new engine. I will have the "first start" in a week or two. I thought that it will be good for the engine to idle for a few hours and after that -- to cruise off-boost for a few hours.
Its well known never to be tender with a new motor.
Lots of load in bursts; different amounts of load and at different rpm's. I drove mine along the seafront with lots of round abouts so lots of slowing down with hard acceleration. I disconnected my turbo's actuator so I could give it some up to 4000rpm without it instantly pushing 11-12psi.
Ive found a good grade mineral or semi-synth oil is best as you still need the oil to give protection as proper engine run-in requires that you load the engine up ie up hil high gear low revs which loads up the bearings
 Share
